Device not configured correctly getting error code 1 (PCI bus 7 device 0 function 1 ) where is pci slot #5 on this M/B ...I have ati X2600 xt at PCI-E . first pci slot is empty , 2nd pci has sound blaster audigy 3rd pci slot has ati tv wonder 650 card any help will be greatly appreciated
Goooooooooooooooooooooooooooooooooooood
Hey there cajununo. The error message you get is telling you that your configuration is wrong and/or you are missing drivers. for your installed hardware. Making the assumption that these were recently installed, I will suggest you go back to basics and pull out all unnecessary devices. Get the machine to post with basic configuration and enter bios setup. Enable all the ports or slots required to seat all the devices you are about to install. Save changes and exit to boot. Then, following instuctions that came with your devices, install one device, ensuring all drivers required have been installed. Restart and then move on to the next. This one at a time approach, will allow you to identify the problem device ( if there still is one ). I hope this helps. Good Luck!
