Question about Dell Wireless Keyboard Optical Mouse w0147
Red light on receiver will not go off
Mouse works fine. Put new batteries in mouse and went through the buttons and the red light stays on.
  • Anonymous Feb 26, 2008
    dell wireless keyboard, the letter and number keys do not work, however the tab and some of the f keys work and the mouse works. The red light on the receiver does not go off.
    thank you for and support
  • 1,142 Answers
There is a green button on your reciever and below the mouse.
press the connect button on both together and release them
Posted on Feb 08, 2008
2 Suggested Answers
SOURCE: I bought a mini wireless optical mouse last year
unplug the usb reciever and plug it into another usb plug. then once it is reconized . press and hold the reviever button down for 5 sec. then press the button on the mouse that should make it resync
Posted on Oct 12, 2009
Testimonial: "that worked! The receiver finally blinked fast then stayed steady and the light on the mouse came on!"
The red light on the top of my mouse is staying red and will not work. I have a battery operated mouse that came with a wireless keyboard as well, i have tried many sets of new batteries, and can not get...
When you put in the new batteries, you may need to press the "Sync" button on the wireless receiver. If it does not have one, I suggest contacting Logitech to help resolve the issue.
Mar 10, 2011 | Logitech Cordless Mouse
I have put in a new battery and the red light is on yet my mouse will not work.
you have a receiver and a mouse on both there are buttons push the button on receiver then on mouse because the receiver searches for the mouse that should work
Aug 17, 2010 | Microsoft Wireless Notebook Optical Mouse...
I put in new batteries but no luck. No lights go ...
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
I bought a mini wireless optical mouse last year at christmas. The batteries went kaput so I put new ones in finally. For the life of me, I cannot find the instructions on how to sync it. I have tried...
Oct 12, 2009 | Computers & Internet
Red light doesn't come on ~ Microsoft optical notebook mouse 3000
Look for a small button that protrudes where the receiver is placed at the bottom of mouse. There are two possibilities for turning on the red light, one is that said button is stuck,if that is the case push it down a couple of times and see if the red light goes on, the other is that the button is broken at it's base. Also check that battery contacts are clean and hold it firmly. Good luck!!! Chawah.
Mar 15, 2009 | Microsoft Wireless Notebook Optical Mouse...
Dell Wireless Mouse dead
now mouse is open & clean by isoprpile & check battery conector after check now mouse its working.
Aug 25, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Targus mouse remote
If the Red Light is on the batteries should be good enough to function. Try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Feb 07, 2008 | Targus Wireless Remote Presenter Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
238 people viewed this question
Alun Cox
