Question about Whirlpool GBD307PDS Electric Double Oven
BM - After Self-Clean Problem -- 30
I have a 30" Electric Whirlpool Double Oven -- Model # GBD307PDQ6.After a self-clean session appeared to finish (control panel indicatedthat cooling started) the control panel and all operations weredisabled/failed. I checked the main circuit breaker and nothing hadtripped. I took off the trim pieces and lifted the front control paneloff to test power to the motherboard. I was getting 120VAC into theboard but the step-down transformer didn't show any voltage (high orlow side). I'm tempted to pull the oven out to locate the two thermaloverload fuses but thought I'd ask an expert first. I have a hunch itmay not be a fuse if I'm getting power to the control panelmotherboard. I'm thinking my motherboard could be the broken link. Whatsuggestions would you have for me? Thanks - Brian
  • 2 more comments
  • murrdogs Jan 30, 2008
    catriver,
    I tested both the lower and upper circuits and found open loops on both. So with that I'm going to follow up with your hunch and buy a lower and upper thermal fuses after pulling out the old ones. When I pull out the oven do I need to disconnect the wires to the terminal block? Any other tips for pulling the oven out? So far I'm very impressed with your feedback so thank you. -Brian
  • murrdogs Feb 04, 2008
    Catriver,
    Over the weekend I was able to pull the oven out and replace the TCO's. Before re-inserting the oven I flipped the breaker back on to test. I got power back to the control panel but after about 1-minute the panel read the following error code (F2 E1). According to my tech sheet this error means... "Keypad keytail not connected". The recommended repair procedure said, "(1) Check keypad connector for firm connection, (2) Press CANCEL, If error code returns after 60 seconds replace keypad, (3) Replace control. I did (1) and after repowering the same error code appeared. Per (2) I don't have a "CANCEL" button on the control panel. Do I need to purchase a new control panel? Is there any chance the problem could still be in the motherboard? I do have go voltage readings on both windings of the transformer. Let me know your thoughts. - Thanks Brian
    Catriver,
    I tried that sequence and the same error did occur. When the power is back on the first thing that is displayed is "PF" and the "TIME". After approximately 60 seconds then I hear three double-beeps and then panel reads "F2 E1". When I called up my local appliance depot store. They quoted $204 for a Control Board with membrane. I'm assuming this is the touch panel and includes the ribbon that connects to the motherboard. Thanks - Brian
  • murrdogs Feb 05, 2008
    Catriver,
    Did you get a chance to read my last comment from Feb. 4th? Do you think I should replace the touch panel which in includes the membranes (estimated at $204)? Thanks - Brian
Brian, I think it would more in the keypad than the control. Try this, kill the power to the oven and disconnect the keypad. If you can, clean the end of the ribbon with an eraser. Plug it back it and see if the error returns. If it does, kill the power, unplug the keypad and power up, let me know if the same error comes up. At least we got the power back to the board. Catriver
Posted on Feb 04, 2008
    President:
  • 878 Answers
Brain, check your thermal fuse first. You can do this at the board. lower oven, p26-2 orange or p26-4 red wire to red wire at the terminal block. Should show closed circuit. Upper oven, p18-4 red or p18-1 red to red wire at terminal block. Should read closed circuit. If open, there is your problem. Control transformer is as follows, primary windings, P16-5 red to p16-7 red, 75 to 95 ohms. Secondary windings, p16-2 blue to p16-3 blue , 2 to 4 ohms. I do believe your problem is in the thermal fuse on the back. Post back, Catriver
Posted on Jan 29, 2008
  • Ron Marek
    Ron Marek Jan 30, 2008
    Brian, just kill the power at the breaker. You should have enough line to slide it out. It's best to get a friend to help you with this. Maybe get some milk crates so you can slide the oven out and rest them on the crates. While some one holds the oven, the other removes the back panel and changes out the TCO's. Catriver.
  • Ron Marek
    Ron Marek Feb 06, 2008
    Brian, looks like you are going to have to go for it. It's the only other thing. If you want, you can get the part at repairclinic.com. If it doesn't work they will refund the money, no questions asked. Catriver.
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
Trying to clean my oven. When I push the clean button it works for a couple minutes and then it starts beeping and an f5 code appears.
heatman101
Sep 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The inner oven glass of my self-clean oven has a small crack. Can I still use the self-clean feature?
No, that may be what cracked it in the first place...the self clean or self destruct feature will noly finish it off for you...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 23, 2010 | Frigidaire 30 in. Electric Gallery Series...
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
When I try to start the self-cleaning oven, ''door'' appears in the display, and then the display goes to F5 E1. The door doesn't even try to lock. I have a Whirlpool Self-cleaning electric range Model #...
there are switches under the cooktop that go bad frequently. i do not recommend ever using the self clean mode in an oven. the oven gets so hot that things have a tendency to melt because they dont build stuff like they used to. there is inadequate insulation in modern ovens. use easy off and follow the label directions. it'll be cheaper in the long run, trust me.
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool GBD307PDS Electric Double Oven Logo
253 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
