Question about Sony VAIO PCG-K35 Notebook
Xbox 360 with this ethernet port?
I have a verizon wireless internet card, and i'm purchasing xbox live sometime soon. can i just plug the ethernet right into the laptop and it will automatically access xbox live through the card, or do i need a modem/router/PC also?
    Problem Solver:
  • 11 Answers
It is possible to do that, but u have to configure ur ethernet port to allow a pc to access the internet thru it. it's simple.
control panel-network-create a new network and follow the prompts..
Good Luck
my xboxlive game tag: mystic00l (it's a L not a 1)
Posted on Jan 29, 2008
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
How to get to internet to x-box live
1. Make sure you have internet access at your place of residence 2. Be sure that your router/modem is working properly 3. If you are using wireless router/modem, you need this http://www.google.com/products/catalog?q=xbox+wireless+adapter&um=1&ie=UTF-8&tbm=shop&cid=5324274914007734077&sa=X&ei=84YLTvepOo3BtgfB8JFn&ved=0CCwQ8wIwAQ 4. If you are using ethernet cables, take one ethernet cable and plug it into the ethernet port on the back of the Xbox 360 console
Jun 29, 2011 | Microsoft Xbox 360 Console
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
Cant git xbox live with internet card in my notebook
As in an internet card that acts as a wireless receiver? If so, these things don't transmit wirelessly, so it's just for internet in your laptop. You need either an ethernet cable running from a land line, or a wireless receiver for the 360 with a wireless router.
May 31, 2010 | Microsoft Xbox 360 Elite Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
How to hookup wireless internet
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 07, 2010 | Video Game Consoles & Games
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
Have one ethernet for computer want to use xbox live so i take out the ethernet from computer and put it in xbox unplug wait plug back in turn still will not connect red x for modem
You should get a cable/dsl router/switch or wireless cable/dsl router/switch and put it between your Modem and network nodes (IE your computer and xbox 360)
So it is modem to router wan port
Xbox 360 to router lan port
Computer to router lan port
You can purchase one cheaply at best buy
look at this link
http://www.bestbuy.com/site/olspage.jsp?skuId=8741365&type=product&id=1202648529130
Jul 29, 2009 | Microsoft Xbox 360 Console
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Sony VAIO PCG-K35 Notebook Logo
99 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
