Question about Saeco VIA Venezia
Frothing works perfect....water is extracted just fine. BUT when I put coffee in the basket and tamp it down and put it in the machine it just makes noise like it is about to drip and nothing comes out, spiratically it will drip an occasional drip here or there but never goes beyond an ounce of espresso? I have owned this machine for over a year and have never had this problem before?
    Problem Solver:
  • 5 Answers
I have a brand new Via that never worked right out of the box. Could barely get any espresso to come through the portafilter. Got a new portafilter and the espresso now flies out of the machine beautifully. Seems they are shippingFrothing works perfect....water is extracted just - 2_bing.gif units with faulty portafilter. Bad news is a new portafilter is like $65. See if you can get them to give you a new one. I had the same issue as you, very little espessso comes out.
Posted on Jan 14, 2010
SOURCE:
Breville 860 - no longer getting constant pressure as the coffee shot is being produced. The pressure gauge fluctuates and the noise is no longer constant while producing the coffee shot. The machine is...
General with machine that the hot water outlet onto the ground coffee is blocked with very fine grounds. You need to clean this hot water outlet. Often there is a philips head screw in the middle of the perforated outlet that has to be undone.
Aug 25, 2013 | Breville Coffee Makers & Espresso Machines
We have a sunbeam cafe series coffee machine that is 2 years old but suddenly under extracts on the pour and cannot reach the extraction pressure we are used to. We grind our own beans as well.
Generally, this is not a problem with the machine but with how you're loading the coffee! Sounds typical of one of these problems:-
Not enough coffee in the basket
Coffee should be filled and tamped to about 3mm below the rim.
Coffee grind not fine enough (too coarse)
Do you grind your own coffee or buy ready-ground? If buying ready-ground, make sure it is for espresso (fine) and not for filter or plunger.
If you have your own grinder, (like the Sunbeam Conical Grinder), then make sure the coffee hopper on top is securely connected to the grinder. I'd been using mine for years on the the finest grind (1) not realising the hopper wan't on right. Only discovered it when I took it apart to clean. Now my grinder is on 9-10 to grind for espresso.
Coffee not tampered down hard enough
You do need to provide a reasonable degree of pressure to tamp the coffee down just right.
Group head not turned tight enough
Push the group handle as far to the right as it will go, then ease it back just a fraction to have the right pressure.
Dec 15, 2012 | Sunbeam Cafe EM6910
My EM100 Espresso Maker will not brew? Water comes out when no portafilter on, but not when filter on for brewing? Help!!
This is a complex problem. 1. remove, check and clean brewhead (round screen above portafilter where water comes out); it can become clogged with gunk. 2. brewhead gasket may be old or damaged, they can be purchased on eBay. 3. brewing basket may have become clogged, I don't know if running cleaner solution through it will help, may have to replace it. 4. Likeliest source of problem is coffee ground too fine and/or tamped down too hard. These are not professional level machines and cannot work with very fine grind or heavy tamping. Try a coarser grind and a light tamp with the larger brew basket. Coffee must be ground with good quality burr grinder for correct consistency. John Saxon/
See my espresso-making blog at motophoto.posterous.com
Dec 15, 2011 | Cuisinart EM100 Stainless Steel Espresso...
After successfully using the machine I tried to make a second coffee. Water continually poured into the tray and the machine sounded very loud (as if it was starting up). I then tried to shut down the...
The coffee grind is too fine, or you are tamping too hard, First remove the portafilter and press the brew button if water flows move on if not remove the shower and clean. Now that we have a nice flow of water without the portafilter. Now we will add coffee to the portafilter, and level it out, do not tamp and try to run a coffee, if that works then the Tamp is the problem, if you tamp and still have the problem then the grind is too fine.
Jan 02, 2011 | Breville BES820 Espresso Machine
I've tried grinds from a very fine to a coarser grind in my Rancilio Silvia, but the water is going through the portafilter/coffee too quickly. When I clean out the portafilter, there is too much dry...
Check the shower screen to make sure it is not damaged. Then try this get coffee ground from the store at #2, 3, 4 and 5 at least 1/4 pound each then use that to figure out what setting works best for your machine, also note the tamping pressure. Fill portafilter to rim then tamp to fill ring in basket.
Aug 24, 2010 | Rancilio Silvia Espresso Machine
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Coffe/water dripping from handle when preparing coffee
On the inside of the basket is a line or ridge close to the top, that is your fill line. If you fill the basket to the top and tamp to that line then that should be perfect. For the portafilter it should be no more than a 90° angle with machine if it goes father then it is time to change the group gasket.
May 20, 2009 | FrancisFrancis! X1 - Stainless Steel...
No flow
Tamp the coffee a little less - run water through filter basket to make sure it is dripping out before filling with espresso grounds. Dry the filter thoroughly before inserting coffee grounds. I would reccomend using double filter basket only instead of the single.
Aug 11, 2008 | Cuisinart EM-200 Espresso Machine
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Everything sounds like its working...but nothing.
It sounds like your filter is clogged.  This can be tricky to unclog, but use the pin that came with the machine.  I have had the most success when I use the pin and try to run H20 (no coffee) through the filter basket.  Sometimes takes several tries, but eventually blows out the clog.
Sep 14, 2007 | Breville Die Cast 800ESXL Espresso Machine
Saeco VIA Venezia Logo
129 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
