Question about Apple iPod MP3 Player
Ipod 4th gen. the wheel does not work + I can't scroll through menu
Hi!
My Ipod wheel just stopped working. Now I can't use the wheel at all.
Any suggestions?
thanks
  • Anonymous Feb 14, 2008
  • 77 Answers
You'll need to replace the click wheel. You can get one on ebay for about $10 and put it in yourself or let a repair shop do it for you for about $40.
This is a common problem on ipods.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Backlight doesn't work on my ipod touch 8g 2nd generation
Common problem with the LCD. It needs to be repaired or replaced!
Tony
iRefresh, iPod repair service
Feb 20, 2013 | Apple iPod touch
How to replace ipod nano wheel control? I need some tutorial. Thanks for helping.
Well you can please follow the below link -
http://www.wonderhowto.com/how-to-install-click-wheel-1st-generation-ipod-nano-248789/
(Here is a video on How to install a click wheel in a 1st generation iPod Nano)
Good Luck!!
Thanks for using FixYa!
Jul 06, 2010 | Apple iPod MP3 Player
CLICK WHEEL IS NOT RESPONDING
Hi!
Please try resetting the ipod by pressing the center and play button on your ipod until it displays apple logo. Also try restoring it to factory settings by seeing this link from apple---
Restoring apple ipod
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Feb 08, 2009 | Apple iPod classic MP3 Player
IPod Nano 3rd Gen...click wheel seems to be frozen....
Hi, First find whether the Hold switch is in off hold position... ( Hold switch can be found at the botton or on the top of ipod) then try:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jan 13, 2009 | Apple iPod nano
IPod Nano (first gen.)
http://serviceman.site88.net/index_files/Apple_Ipod.htm
Aug 05, 2008 | Apple iPod nano
Ipod wheel problem
Try to format the drive and install new apple ipod software.
Aug 04, 2008 | Apple iPod MA446LL/A MP3 Player
IPOD Third Generation
try a reset first
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Apr 21, 2008 | Apple iPod nano 3rd Generation
2gig Nano stuck on hold
The fact that it works fine when plugged into a power source would suggest your battery is going bad (or has gone bad).
Just a guess.
Feb 18, 2008 | Apple iPod nano
Ipod will not turn off
Press both the center and menu buttons until the ipod shuts off (about 5 seconds.) it will then reboot itself and the problem should be fixed.
Nov 13, 2007 | Apple iPod nano
Click Wheel
This usually happens if the iPod wheel is defective, sometimes caused by getting in contact with water sometimes simply through wear and tear. If you're out of warranty, There are specialized online tutorials with iPod Repair instructions that will guide you through the steps of taking it apart and replacing the wheel altogether otherwise you'll have to send it to any third party iPod repair service and they'll replace the wheel for you.
Nov 11, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Apple iPod MP3 Player Logo
46 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
