Question about Car Audio & Video
MTX car amp doesnt turn on
The wiring outside is good, this I am sure. I would like some one to help me fix it from the inside. If there was a short, what electronic component could of went bad. i have the amp opened up but I dont see anything burnt or broken or loose.
    Problem Solver:
  • 10 Answers
Opening electronics is not usually the answer, did you check the power on cable? is the one between ground and battery
Posted on Feb 02, 2008
Why does the mtx tc 4001 remain on even when the system is off
You more than likely have a transistor that is shorted out inside of the amplifier.
Nov 08, 2011 | Car Audio & Video
My mtx thunder 6500d amp hums when connected light turns on but no output
Make sure you have a proper ground wire connection. The ground wire should be connected solidly to the vehicle chassis in a paint-free location. If it is loose or there is paint t the connection site, you will have problems with the amp output. Also check the speaker wires to see if they are touching the vehicle chassis. This will cause a short circuit and you will not have output from the amp. Finally, check the leads from the head unit. They should be RCA cables, and should have a good connection to the amp.
Feb 22, 2011 | MTX Thunder 6500D Car Audio Amplifier
Connection
My guess is a short in your 12 volt remote turn on wire or you have it wired incorrectly behind the dash. If you're sure you have a good ground and a solid battery wire the only other issue can be your remote wire. Your remote wire is what kicks the amp on and illuminates the power light.
May 31, 2010 | MTX Thunder 251D Car Audio Amplifier
Amp burned out
yes you shorted the output transistors and replacing them will fix your issue. inside the amp you will find three legged transistors that mount to the amps body/heat sink. replace all of them.
good luck man.
Jan 23, 2010 | MTX Thunder 4250D Car Audio Amplifier
No sound from speakers, but there is power to amp
make sure the power wire and the remote wire have voltage. at least 12 volts. make sure the ground wire is good and has a good solid ground. after that make sure the rca cables are getting signal from the radio. if you have a small speaker or tweeter you can touch the wires from the speaker to the rca cables and it should play music very quietly. meter the subs and make sure theyre ok and not shorted or bad. if all that checks out good.... the amp is probably bad. start with all the simple stuff and work youre way up. if the amp has good power and signal and good speakers then the only thing thats left is the amp. good luck
Dec 29, 2009 | MTX X702 Car Amp
About 6 months ago i had installed the mtx thunder 6500d amp to run my 2 rockford fosgate power T1 12inch subs and every thing was great untill recently it stop puting out sound it still powers up and...
good morning and welcome to fixya. not a bad setup you have here at all, you ned to start by checking the speaker wires inside the box to the connector inside and then the wires from connector to amp on outside. if everything looks fine there, then you need to check the amp for power out of the rca plugs to make sure the channel is not dead. if you are looking for a new amp you can try several different ones from fosgates new line up to soundstream's. im running 4 polk momo 12's on the tarantula amp and love it. they are great amps. hifonics also has a new line up pretty cool stuff, heard really good things about there stuff to. good luck and let me know so i can help you out.
Mar 08, 2009 | MTX Thunder 6500D Car Audio Amplifier
Mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
Aug 19, 2008 | MTX Thunder 1501D Car Audio Amplifier
My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
Sep 30, 2007 | Car Audio & Video
My 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
Apr 03, 2007 | MTX THUNDER7801 SUPER AMPLIFIER CLASS D...
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
