Question about Hawking HWPS1UG Print Server
Can't create file: pslog
Using a print server Hawking HWPS1UG
Printer is connected to printer server and this one is connected to my router, I get this annoying error box and has to click 10 times before it goes away.
Can someone please help?
2 Suggested Answers
SOURCE: Does the Hawking HWPS1UG support the Lexmark 2600
Yes it does, it IS Multifunction, IE: Able to do More than one thing
Posted on Mar 13, 2010
Reset password on hps1p
I would suggest your download PSADMIN and Installation software from Hawking then push the reset button on the print server and start again.
Nov 22, 2013 | Hawking 10/100 PRINT SERVER MINI 1...
How to connect my printer to a router
This model Canon printer has onlt an USB connection to a computer.
The only way to connect this printer to a router is to install a printer server with an USB connector, connect the printer to the print server and then connect the print server to the router using a LAN cable.
The printer driver needs to be installed on all the computers on your network and then to the printer properties then Port tab and add a TCP/IP port then configure this port with the print server's IP address.
Do a test print and if the test print is OK then printer is installed correctly.
May 29, 2012 | Canon iP2700 Inkjet Photo Printer
Can i connect Hp F380 all in one printer to Linksys wrt54g, and i am using macbook, help
From looking at the printer information and the router information, you will probably need additional equipment to make this work.
The printer connects to computers using a USB cable. It does not have a network connection, either wired or wireless built in.
That means you need a print server to connect your printer to the network. Some routers have a print server built in, but the WRT54G isn't one of them.
The print server will have some USB ports to connect the printer to, and connect to the router with a cable, or wirelessly.
HP shows this option:
If you can find that one, it might work the best. Many print servers have a hard time with all-in-one devices. They are usually able to print just fine, but scanning is troublesome. Make sure to review information about any print server you get, or router with built in print server to make sure it does everything you need.
Considering the price of a print server, it might be a better option to get a new printer that has built in network support. They are more likely to work easily and well. But watch carefully to make sure it can do everything you need (print, scan etc) over the network.
May 04, 2011 | Linksys Wireless-G WRT54G Router
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
Vista 64 cannot print using USR5461 print server
sir chuck, try NETWORK MAGIC it can fix your problem from PRINTER & file sharing and others. It fix network problems regardless of Operating System , windows, linux, mac etc.
May 04, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Cant find the Print Server IP
when you tried to ping the restored ip for the print server did your computer was in the same subnet? if not try to configure your machine ip to be in the same subnet for your print server ip.
Jun 14, 2007 | Hawking HWPS1UG Print Server
Macintoshes and Print Servers, the PS110 in Particular
Topic 1. What do I need to connect a Macintosh to the PS110 Print Server? A PostScript printer with a parallel interface, a Mac running MacOS 8.6, 9.x, or 10.x. (NETGEAR products are not supported for earlier versions.), and Ethernet cables to connect the Print Server to the printer, and the Print Server to your Macs, and to a router. NETGEAR's RP614 router is known to work connecting the PS110 to the Internet with Macs. Topic 2. How do I avoid losing my network configuration when restarting my Mac? When changing theMacOS configuration it is best to use Configurations (MacOS 8.x or 9.x) or Network Location (MacOS 10.x) settings instead of changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). That way you can be sure the changes will not be lost after rebooting. To Create a Configuration in MacOS 8.x or 9.x 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. Select File > Configurations > New Configuration. 3 . Type a meaningful name for your new configuration (e.g., NETGEAR Wireless Router). 4 . Make your changes to the AppleTalk or TCP/IP settings. 5 . When closing AppleTalk or TCP/IP choose Save Changes. Whenever making Configuration changes for settings in MacOS 8.x or 9.x, open File > Configurations or press Command-K. Changes in Configurations are saved after rebooting. To Create a Network Location in MacOS 10.x 1. Open the Apple Menu by clicking the Apple icon in the upper left of the screen. 2. Select System Preferences. The System Preferences window displays. 3. Click Internet & Network > Network. The Network Settings window displays. 4. If the window is locked, click the Lock icon in the lower left to unlock the Network window. (You may be asked for a username and password.) 5. Click the pull down menu next to Location at the top of the Network window. 6. Select New Location. 7. Type a name for your new location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left to prevent further changes. The Apply configuration changes window displays. 10. Click Apply to keep the configuration changes for the newly-created location. 11. Close the Network window. Topic 3. How do I connect a Mac to the PS110 Print Server? For MacOS 8.6 and 9.x 1. Follow the instructions in the NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-PostScript printers with Macs on the PS110 Print Server.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer to be used with the PS110 Print Server on your Mac. 5. Open Chooser from Apple Menu. 6. Select LaserWriter 8. 7. Select the PostScript Printer to use. (This is probably the description for the PS110 Print Server and may have a name like ?PSD90335?. This name may be different on your computer.) 8. Click Setup. 9. Click Select PPD. 10. Select your printer from the Printer Descriptions list. 11. Close the Chooser. 12. Click OK. A message displays: ?You have changed your Desktop Printer.? You can now connect to the RP614 Router Gateway, and to the Internet. For MacOS 10.x 1. Follow the instructions in the printed NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-Post Script printers with the Mac and the PS110.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer you will be using with the PS110 Print Server on your Mac. 5. Open Utilities > Print Center in the MacOS 10.2 Applications folder. The Printer List appears. 6. Click Add. The Printer Selection window appears. 7. From the top of the Printer Selection window, select AppleTalk from the first pull down menu. 8. Select Local AppleTalk Zone from the second pull down menu below. 9. Click the Print Server from the list in the window. PSD90335 ? PostScript Printer in the case of this test. 10. Click the pull down Printer Model, and select the model of printer connected to your Print Server. A list of printers displays. 11. From the scrolling list select the Model Name of the printer connected to your Print Server. 12. Click Add. 13. Printer List displays with the list of printers and print servers connected to your Mac. Select the name of the Print Server from the Printer List. 14. Click Make Default. 15. Close the Printer List. 16. Open a file and try printing it. You can now connect to the RP614 Router Gateway, and to the Internet.
Feb 19, 2006 | NetGear RP614 Router
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Open Questions:
HawkinG Wireless 1-port USB Print Server doesn't recognize imageclass MF6530 So, I've been slowly building my company's network over the past week (It was very very poor.) So now I'm installing some devices to utilize the networks capabilities. So we have a printer that's a Canon imageclass MF6530. Freaking nice right? Well we don't even utilize 9/10ths of it's capabilities because all we use it for is a hard copier... Lame. So I got the cheapest network printer server that I could find. My mistake I suppose. I needed it to be wireless, and well this is what I got for a cheap price non the less (35 bucks, i knew that was a mistake but still bought it. lol) So I did all the neccessary steps listed in the manual (why a wireless print server doesn't have all the software needed to configure it build into the actual server, I do not know.) So after I found out that there is no way to config the printer server via network connection with out te use of te softwarer, i go ahead and install everything. Setup runs while the printer is connected, the PS (print server) is hooked to my router via long *** cord (wireless apparently can't be setup with out having it hooked to some sort of network device to communicate with it although it did state tat it was possible, yet I never was able to connect it.) Yay, I have a print server. Yet the program was faulty, froze, and I had to restart it and it didn't correctly setup the unit through the autostart install wizard. SOO I manually went into the programs and used there config utility, that didn't work. Went online, downloaded all the updated software (yet I didn't check the version difference between sfotware so I don't even know if it was an upgrade) but sure enough, everything started to work. I could access my print server efficiently, and configure it to the settings I wanted. NOW, the problem. It simply doesn't show my printer hooked to the USB device. So my trouble shoots: 1. Checked the printer, it's on, USB enabled, setup to be connected. 2. Checked all the cable connections (okay) 3. Checked the printer on a laptop to insure that the usb connection works properly, printer was recognized and installed. (I did a direct connection from printer to laptop via USB - no print server) 4. So then I added my dell printer to the mix (just purchased it 10 days ago), and wala it can see my DELL printer on my print server and allows me to install drivers. Cool, but it's already a wireless enabled printer, sooo useless for me. So that's were I am at. Anyone know of anything that I could try? I mean, it doesn't really allow me much ability to configure the unit or make any modifications to it enough to where I could get it to recognize my printer.
Feb 26, 2017 | Hawking HWPS1UG Print Server
Hawking HWPS1UG Print Server Logo
140 people viewed this question
Top Hawking Computers & Internet Experts
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
