Ge profile won't drain
Hi my GE profile Harmony WPGT9350 copl won't drain
  • neeciem Jan 29, 2008
    Thanks!!!! Yes it did!
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
I have a GE Profile Harmony Washing Machine WPGT9350. The problem I am having is one I believe somehow related to balance resulting in a noise of the inner drum rubbing/banging against the outer drum. This...
GO TO www.repairclinic.com ENTER MODEL NUMBER, SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 NOW LOOK FOR PART1089518 THIS IS THE BALANCE ASSEMBLY. IT IS SUPPOSE TO HAVE WATER IN IT. CLICK THE PIC AND LOOK AT ADDITIONAL. THE PROBLEM YOU ARE HAVING IS EITHER THE SUSPENSION ASSEMBLY OR SPRINGS BUT NO YOU SHOULD NOT HAVE DRILLED THOSE HOLES. YOU MAY CALL REPAIRCLINIC AT 800-269-2609
May 01, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge profile notice: a problem has been detected with this unit
hello: I have a its a GE PROFILE WPGT9350 washer and i have that pop up when i push power button what can i do if you can help this missg "Notice A problem has been detected with this unit if you can tell me how to get to Service Mode Diagnostics" thanks my email is [email protected] Actually I have tried unplugging it and letting it rest and plugging it back in, same message. Thanks anything can help
Feb 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Msg after entering service mode
There are 5 solutions for this problem
1) house voltage (voltage to low)
2) Inverter
3) Motor (if motor only turns in one direction)
4) wire connection to the low voltage
5) Hall sensor at rotor (only turns a 20% of speed)
let me know if I can help you more...
Aug 05, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
300 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
