Question about LG enV VX9900 Cellular Phone
Lg front screen cracked
I need to find out where to find a new screen or the proper name for it atleast i have an orange env vx9900
  • bestbet98296 May 11, 2010
    Hey Hollowtech 2:
    You sound like you really know the LG enV, my son's inside screen cracked after 16 days of owning. Would you be interested in replacing the screen?
  • 4 Answers
Step one Take out battery!! to avoid esd (Electro Static Discharge that may ruin the new screen or fry your phone), there are four screws in the corners covered by a sticker material two over the speakers two under in the far corners hidden with stickers. remove those stickers with a sharp flat bladed eyeglasses screwdriver. use a #00 Phillips head screwdriver to undo these screws. Look along the edges of the face of the phone you will see where the colored piece meets the gray piece. I used the flat bladed screwdriver and carefully wedged these pieces apart and used my finger nails to carefully separate without penetrating too deeply with the screwdriver (that may crack the internal screen). pull the cover off gently you will notice after you removed the keypad there is a metal cage housing the internal screen gently pry it from the side of the end key You will see a 7 by 3 mm box underneath with gold connectors do not touch these the oil on your fingers will prevent the screen from working properly this is the connection for the outer and inner screen to the mother board on your phone (right side from top view) it may take some effort as mine was tight you will see the screen and zif connector for the front lcd. also the outer speaker is soldered to the lcd circuit pad. Take a picture with a digital camera if you need to de-solder from the old and resolder onto the new lcd (this is a pain in the ass and the pictures will help trust me!!!) lift the black clip on the zif connector and remove the screen ribbon while taking care not to pull on the earphone assembly use the flat head to remove the magnet and earpiece noting their orientation for later re installment. de-solder from the old lcd and re solder connection of these components to the new lcd. Place them back into their respective positions tucking the wires so that the cage will not pull on them when you push it down (there is a small gap but still be very careful) Place the zif connector ribbon in the holder and slide the plastic retaining clip back down. Flip the cage into its original position and push firmly into place. re-install the key pad and face plate. re install battery and power on. my screen didn't work at first. i had to press rather hard to get the pins to seat properly on the one and four button area after i closed everything up, where the part is i said not to touch, so don't be discouraged if you put it all together and neither screen works (I found this out after i got rather angry after all that work) This is all a very overwhelming amount of work but i learned a great deal. you may try ebay for a broken env or one with a bad ESN they go cheap <100$ and you can use the screen and speakers without soldering. That would cut the probability of failure by 75%. The contacts are ridiculously small 1mm by 2mm super hard to solder properly but everything else was simple. screens are available for 30.00 on ebay they are new but again comes the soldering issues. wish lg would use some sort of pin connector instead of soldering these contact directly to the phone that would make this phone way more easier to fix. hope this helps good luck
Posted on Jan 31, 2008
  • 113 Answers
You can get a replacement vx9900 screen at
Posted on Apr 20, 2008
Lg enV VX9900 callers can't hear me.
Check you micro phone.....and make sure it is working properly by recording your voice and then listen it working Properly? If not hen repair or replace it with new one.from mobile repairing shop...
Oct 19, 2010 | LG enV VX9900 Cellular Phone
My touch screen on my enV touch won't work but
better go to settings and do pen calibration. or check for the ribbon attachment properly
Sep 10, 2009 | LG enV VX9900 Cellular Phone
Broken front screen...want to change out with another screen
Have to take it in and have s/n changed to new phone
May 26, 2009 | LG enV VX9900 Cellular Phone
LG env vx9900
are you trying to buy someone's env?
Oct 06, 2008 | LG enV VX9900 Cellular Phone
You need to change screen.
May 18, 2008 | LG enV VX9900 Cellular Phone
Cracked screen
Take it to a repair shop.
May 16, 2008 | LG enV VX9900 Cellular Phone
Screen cracked
Id contact LG for info on a replacement screen, might cost alot.
If you have warranty maybe that would save you, but im not sure does warranty repair something caused by the user.
Mar 09, 2008 | LG enV VX9900 Cellular Phone
Cracked screen
I've had my enV for about a year, now. within the first month, I cracked its screen. I have both insurance and a warranty for it, but Verizon is unimpressed-- they suggested that I either purchase a new model, or perhaps buy the enV 2. it's whatever.
Feb 28, 2008 | LG enV VX9900 Cellular Phone
My front screen is cracked!!!!
Go to the post titled "Removing cover from LG 9900" started by Wreck 75 (me). A dummy phone is exactly what you need - I thought I saw some orange ones on EBay when I was shoppingfor mine. It is a shame that Verizon plays dumb on this. Replacing the cover turns out to be a quick and easy fix. I
Jan 05, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
1,283 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
