Question about Casio HR-100TEPlus Calculator
% key is stuck on
I can not get the % key off.
  • 682 Answers
Use air can from radio shack and use dry cleaning spray while you press the button many times
Posted on Feb 29, 2008
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
Key stuck in ignition in park. Check charging system comes on. Dealership says it might be a fuse.
Key Stuck in Ford Fusion (2006 model) - YouTube
? 1:21
https://www.youtube.com/watch?v=3LVQttFOzGA
Jun 18, 2014 - Uploaded by Jessica East
#Ford #Fusion #Key #ignition #Stuck #FordFusion2006. ... i have a 2006 mercury milan and my key got stuck in there last night,... it to park with a little bit of force. will see what happens next time. good video, nice to know.
Key Stuck in Ignition While in Park
www.2carpros.com/.../2007-ford-fusion-key-stuck-ignition-while-park
Dec 16, 2012 - KEY STUCK IN IGNITION / SHIFTER BINDING CONDITION FORD:2006-2007 Fusion LINCOLN: 2006 Zephyr MERCURY: 2006-2007 Milan
Nov 06, 2015 | 2006 Mercury Milan
2003 range rover ignition key off power still key stuck in position 1
some of these electric interlocks require the brake pedal stepped on for releasing..have you tried that? along with shifting fully into park a few times?
Jan 26, 2014 | Cars & Trucks
Keyboard stuck
If you are addicted to your laptop, or are an overzealous typist, you may be dismayed when a key on your laptop becomes stuck. However, just because a key gets a little sticky, you don't have to run out to the computer repair shop. There are plenty of practical steps you can take to fix your stuck key right at home that don't require any fancy equipment, just regular household items.
1.Clean the area around the affected key. Use a damp cloth to clean the surface of the key (and surrounding keys) and then use a dry cotton swab to clean under the stuck key. Be careful not to pry the stuck key up with the cotton swab, as this could break the stuck key.
2.Press firmly on the stuck key. Sometimes after small dust or particulates are removed, the stuck key will pop back into place. However, if this is not the case, continue on with Step 3.
3.Pull out the fingernail cleaner extension of your fingernail clippers. This is the flat extension with a little hook on the end. Place the small hook under the left corner of the stuck key. A common reason that keys get stuck is that the collapsible spring becomes off-center. Gently push the key from side to side until it clicks into place. If this does not happen, you will need to disassemble the key completely.
4.Lift the top part of the key with the fingernail cleaner. You will see a collapsible plastic hinge (this is known as the Key Retainer) as well as a little rubber piece. Take both of these out. You will see a flat surface. Run the cotton swab across this surface to remove any dust.
5.Place the key components back in the keyboard. Place the rubber part on top of the metal circle you just cleaned with the cotton swab. Then place the key retainer (big side down) on top of it, and "click" it into place. It is very important to be careful with this step as these small parts break easily. Then place the stuck key on top of these parts and then give it a solid tap to click it into place. Your key should work now.
Sep 28, 2011 | Computers & Internet
How to remove something stuck under a key on y computer?
Hello.
Hope this helps.
Sep 25, 2011 | Toshiba Satellite P105-S6197 Laptop
The O,L,9 keys are not working in my toshiba satellite M105-S3002 laptop., any help is a big tnx.
Hello.
• 1
• 2
• 3
• 4
• 5
Hope this helps.
Aug 02, 2011 | Joy Toshiba M105 S3002 Notebook
The middle c of my sx-k700 Technics keyboard is not working. How can i fix it?
Mar 14, 2011 | Technics Audio Players & Recorders
Keys Stuck in the Ignition , preventing turning off the engine.
Is the key stuck because you have an automatic transmission and you are unable to shift it into P (park)?
Feb 05, 2011 | 2004 Saturn ION
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
Casio HR-100TEPlus Calculator Logo
41 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
