Question about Canon PowerShot SD850 IS Digital Camera
Canon Powershot My dog jumped up at me while I was trying to take a picture, and needless to say she knocked the thing right out of my hands. The lens now won't retract properly and the two outer most pieces of the lens just kind of rotate freely. I can get the camera to turn on - but it wont focus because of the lens issues. What do I do??
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 29, 2008
Damaged lens
With just a little luck, the scratch is not too big, and you won't even see it on most pictures. Don't try to remove the scratch, because the front of the lens has a coating you can remove very easily. That will do more damage to the pictures then a scratch. You could contact a Canon repair centre, and ask what it would cost to replace the lens. I think it could set you back more then a new camera will cost, but always worth trying. If you don't see a thing on the pictures, leave everything as it is right now.
Only clean a lens with a lens pen, you can buy in every camera shop. In a camera shop you also can buy other cleaning suff special for lenses. Never use fluids that are not special for use on lenses, or you will also damage the lens.
Jan 02, 2014 | Canon Powershot A2000 IS Digital Camera
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
Thin line down the middle of the screen
Mine was returned to repair 5 weeks after purchase due to a black spot in every picture. It was not the LCD but the lens or de CCD. The whole lens was changed. Try first to update software or restart
Nov 10, 2011 | Canon PowerShot SX210 IS Digital Camera
I have a Canon PowerShot 850IS that is about 3 years old. It has been a great camera...up to this point. Just recently I went to take some photos and the bottom half of the images are blurry. Seems odd...
Could be that the lens cover doesn't open fully or that perhaps there is a smudge on the bottom part of the lens. Maybe a water drop. IF the front optics are dirty, use an optical-quality lens cleaning solution and cloth (if you have glasses, the lens cloth that came with your glasses). Apply a very small amount of cleaner to the cloth and gently clean the lens.
If the lens cover doesn't open, could be a grain of sand. The only thing to do is to gently move the lens cover in and out & hope the sand works its way out.
Mar 02, 2011 | Canon PowerShot SD870 IS Digital Camera
Internal dust speck on Canon A720is in same upper right corner
If dust is in the camera, it must be opened. I suggest not doing this yourself. Lookup a Canon dealer in your region and ask for support.
Jul 22, 2009 | Canon PowerShot A720 IS Digital Camera
SD1000 with stripey pictures after dropping on lens
Sounds like you need a new camera. Canon's repair centres are not cheap!
Jun 06, 2009 | Canon PowerShot SD1000 Digital Camera
RE: Canon solution
It is most probably that your hand was in the way when the lens is trying to come out.
Try restarting and make sure no obstructions are in the way of the lens.
Sep 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Dropped my camera.
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 22, 2008 | Canon PowerShot A85 Digital Camera
CANON POWERSHOT SD400
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Jan 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD850 IS Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
