Question about TruTech PLV1615T 15 in. LCD Television
T2000-ft atsc Trying to hook up a VCR to this thing. VCR is connected right. Do I have to push a button somewhere on the TV? Thanks.
Cannot get the autoselect to come on the screen and only have a blue screen no volume and cannot get the tv to come on any suggestions?
bmc 7/23/08
Posted on Jul 23, 2008
Trying to connect vcr do i connect it to cable box or to back of tv. tv is on the wall thats why I,m asking
If u plan to just to watches video only,than just used a RCA AV component RYW connections hook directly to the LCD tv is find.But if plan to record shows and things to the VCR tapes,than the VCR unit must hook through to the cable box.
Nov 22, 2010 | Televison & Video
Big Button Remote Control
This is because you did not use the right remote code. Try trying different codes and test different functions with your recorder. Try searching on the Pioneer wesbite for remote codes. I would get the codes for you, but I don't have your model number so I can't. You can search for them yourself or comment back informing me of the model.
Hope this helps :)
Jan 25, 2008 | Televison & Video
Can I hook up a vcr to my new rca tv
Connect the red-white-yellow (left-right-video) outputs of the vcr to the corresponding inputs on the side panel of the TV.
Sep 21, 2009 | Televison & Video
Won't hook up to dvd player despite all connection attempts
Two things you can do. Find remote for your TV on ebay or call the company and order one.
Another thing is you can use the input curently set on your tv and connect the vcr there and thorough the vcr connect other devices
May 21, 2009 | Toshiba 27A43 27" TV
I'm trying to hook up my vcr to my digital box and tv. I think that I have the connections right but when I try to record a tv channed it doesn't record. What am I doing wrong? Or how do I hook up my...
Make sure your VCR is on channel 3 or try channel 4. Also, make sure your VCR is set to VIDEO or VCR and not TV.
A better way to do this is to connect the cable box to the VCR using the composite cable (yellow/red/white) cable. Then, connecting the cable box to your TV with component cable (red/greenblue) cables. This will only work if your TV has component in. If not, then connect the VCR out composite (yellow/red/white) to the TV. Or use the coax cable from the cable box labeled TV/VCR right to your TV. Make sure your VCR is set on LINE1 or LINE.
May 02, 2009 | Memorex MVR2031 VHS VCR
VCR shows "PLAY" on machine but doesn't show on TV
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | GE VG4054 VCR
No signal
You need to find which is the right channel. It is usually AV2. However make sure you plugged in all the cables to right places. Also, call your cable company and ask them which channel might be, since this new HD tv are so different.
One more thing, If you have a VCR/DVD connected to the TV, you need to check the channel of the VCR/DVD
Artgirlny
Jul 12, 2008 | Philips 47PFL7432D/37 TV
Son pressed something and now DVD won't work
well there could be two things going on here that i can think of, one the scart lead between the dvd and the tv is not i properly vica versa for the dvd player, the other thing is the button which changes the av channels could have been pushed so simply push the button while the dvd os on and find the av channel, the button looks like an arrow going right hope it helps.
Jul 04, 2008 | Panasonic Televison & Video
RCA VR355 recording problem
Are you sure the reciever is coming through the vcr.? are you hooking it up through a/v on vcr?
if so hook from a/v out from directv to a/v in
jacks on back of vcr. and turn vcr on a/v channel
to record it. you will see the picture as you record it. if the vcr isn't on a/v channel it won't record it
If you use ch 4 or 3 to record it you
hook up directv to cable in on vcr and you
have to turn vcr on that channel and see it coming
through it you have to push a button on satlette
remote to make it come on the vcr on the channel
or it will record snow. and you have to push
another button on vcr remote if you haven't
already to get the vcr on ch 4 or 3 on your tv
or if u got it through a/v turn tv to a/v channnel.
just beacuse you see the picture coming through
your tv doesn't mean it going through your vcr
you could be just seeing it through the tv only.
you will see the vcrs graphics or vcr channel number on your
tv too along with the directv channel if it's hooked
up right. notice the vcr won't record it's own
graphics or channel number on the screen but it will record the directv's graphics. and it won't record the tv's own grapic channel number either.
to make sure it's right you will see 3 graphics on
your tv the own tv's channel number or a/v
the directvs and the vcr's channel number or a/v
on your tv if you see these you know it's hook up
right.
Nov 11, 2007 | RCA VR355 VHS VCR
TruTech PLV1615T 15 in. LCD Television Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
