Amana AAC081STA Air Conditioner
It displays a backwards 3 followed by a 0, otherwise no lights are on and it won't turn on at all.
  • choim Jan 29, 2008
    The dog chewed off the sensor clipped to the radiator-vanes that has 2 thin wires and plugs into the board. Perhaps the unit self-tests upon replugging into electricity and won't operate until that problem is addressed? It was unplugged during renovation after a fire 15 feet from the unit. The dog chewed the cord in half and I wire-nutted it back together. The small fuse in the board tests good (120 volts flowing.) The electrical receptacle measures full 240 volts.
    Scholar:
  • 72 Answers
That's an E0 code, and it means the main circuit board is fried.
Posted on Jan 29, 2008
  • Andrew Boulware
    Andrew Boulware Jan 29, 2008
    If there are no capacitors popped or resistors or traces burned on the board then a new sensor is probably all it calls for. Always go with the most obvious problem first, most of the time it's the fix. If you're U.S. or Canadian based, then Century or Wilmar maintainence supply will be able to help you find the part. If not, I don't know, you'll just have to do a little digging for a supplier.
How do I replace the fan?
Free Amana Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Amana
Products 1 - 10 of 10 - Amana Air Conditioner 18M23TB. Amana Room Air Conditioner Use And Care Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade .
Jul 10, 2015 | Amana Portable Air Conditioner
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    How do i fix reversed 115 polarity on a heat unit amana
    Can you be more specific with your question? A 230V unit won't work with 115V power. Reversed polarity may just mean that the outlet is wired backwards and the wires need to be switched around.
    Nov 01, 2011 | Amana PTH153B25AJ Heat Pump Air...
    What does E1 mean?
    E-1 error code refers indoor room air sensor Fault. You will need to Replace it
    Jul 18, 2011 | Amana AAC081STA Air Conditioner
    Amana Quiet Zone air conditioner 12m12ta
    Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
    Jul 17, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
    I have an amana portable electronic air conditioner wont turn on
    try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
    Jun 30, 2009 | Amana Portable Air Conditioner
    How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
    This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
    Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
    Amana APO95R Turning Off/Tank Light (!) On and Off
    There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
    Jun 15, 2008 | Amana Haier AP095R Air Conditioner
    Heating & Cooling Logo
    139 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
