Hi There
I have this for you to read and hope this helps you.Let me know how it goes.
F/H
No
water detected entering machine or Pressure switch trip
not detected.
If after 30 seconds the control does not detect water entering
machine and then valves will be turned off and the error
code will be displayed.
Or
If
the control has turned the water valves on and after 8 minutes
the flow meter has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip,
the valves will be turned off and the error code will flash.
Press
PAUSE/CANCEL twice to clear the display.
Thank you for writing to fix ya.
1. Make sure that both valves at the water source(s)
are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged
screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and
properly connected to Tub and Pressure switch
Best Regards Richard
