Question about Samsung TXM3296HF 32" TV
Samsung txm3297hf will not start
My Samsung txm3297hf shut down, I attempted to start the set however the screen will not come on. It Will make sound from the channel it is on for 2 seconds then shuts off. Can you assist?
    Genius:
  • 1,067 Answers
R 818 is off value or the IHVT needs soldered or replaced.
That's what I have seen...
Call your Samsung Authorized Service Center, they have the SUPPORT of Samsung to fix these faster
Posted on Jan 29, 2008
  • nick helpap
    nick helpap Jan 29, 2008
    power supply section if their is a defective resistor or semiconductor device. cheak this also
Can get picture but no sound. Can get sound when DVD is playing but not cable
try to check the cable that links in your tv if ok your sound IF has a trouble try to adjust it just a little bit if still does not work put a ceramic capacitor to the IF.
Oct 13, 2010 | Samsung TXM3297HF 32" TV
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Where is the lamp door cover located
Hi, there is no lamp door and it doesnt have a lamp neither since your tv is a CRT (Cathodic Ray Tube), only DLP's and LCD Projection TV's, For this issue you will really need to consult it with a Repair Center, CRT's are very frindly to fix, and it could be a issue on a small component if it is it will be very cheap to fix.
Jun 26, 2009 | Samsung TXM3297HF 32" TV
Vertical rolling during bright scenes w/ high white content
power supply voltage not stable check capactors and look for dry joints.
May 02, 2009 | Samsung TXM3297HF 32" TV
Samsung TXM3297HF shuts off after 2 or 3 seconds
Usually means your TV's lamp needs to be replaced. I'd need to know the sequence of blinking to really determine this.
Nov 27, 2008 | Samsung TXM3297HF 32" TV
Samsung TXM3297hf
Look for a small flat Ic attached to a heatsink with about 11 pins. That should be the vertical IC. Resolder the pins first. If that fails to resolve the problem, replace the IC and update this note with your results. The IC should be marked LA7837 or something similar.
Dan
Oct 14, 2008 | Samsung TXM3297HF 32" TV
50 inch samsung flat screen television
fan # 2 is having problems; maybe missing voltage or broken fan
good luck
Sep 10, 2008 | Samsung TXM3297HF 32" TV
Set shuts itself off
sounds like a solder issue on the main deflection board. Check for signs of cracked or dull solder on that board. Its the large board on the right looking in from the back
Jun 30, 2008 | Samsung HCM4216W 42" Rear Projection...
TXM3297HF Samsung TV shuts Down
Hi!! Kindly check the power supply section if their is a defective resistor or semiconductor device..thank you.
Jan 29, 2008 | Samsung TXM3297HF 32" TV
Samsung TXM3296HF 32" TV Logo
112 people viewed this question
Jerry Greenberg
Jerry Greenberg
