Question about CTX S762A 17" LCD Monitor
Monitor turns off
I have a problem,my monitor turns off every 30 minutes automatically and tuns on after about 3 seconds..what should i do?
  • 54 Answers
Sir\maam i think there something wrong with the power supply of your laptop,,tv kindly check the power supply section,,,hope to help you thnkzz??
Posted on Jan 29, 2008
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
I can't figure out how to set the time and date on the HEM7300REL blood pressure monitor. I have a manual and have followed the instructions without results. I don't see a reset hold on the machine. do...
If you remove and replace your batteries...you will not lose the memory. The unit will store up to 90 measurements in non-volatile memory...so it will stay there.
I have the same unit and use these directions....and never had issues with setting the date and time.
2.2
Setting the Date and Time
Your blood pressure monitor automatically stores up to 90
measurements values with the date and time. To make use of the
memory and average values functions:
• Set the unit to the correct date and time before taking a measurement
for the first time.
• If the batteries have been removed for more than 30 seconds, the
Date/Time setting will need to be set.
1. Press and hold the Date/time
setting button (
) to adjust the
date and time. The year digits
(2008) will flash on the display.
2. Press the Memory button ( ) to
advance the digits one at a time.
Notes:
• The range for the year setting is
2008 to 2030. If the year
reaches 2030, it will return to
2008.
• If you hold down the Memory
button ( ), the digits will
advance rapidly.
3.
Press the Date/time setting
button (
) to confirm the setting
when the desired number
appears on the display.
The year is set and the month
digits flash on the display.
4.
Repeat steps 2 and 3 to set the
month.
The month is set and the day
5.
day.
The day is set and the hour digits
6.
hour.
The hour is set and the minutes
7.
minutes.
The minutes settings is set.
button (
) to turn the monitor
off.
When adjusting the date and
time, press the Date/time setting
button (
on, follow the steps above, and press the START/STOP
button to turn the monitor off.
Good luck.
Semper Fi,
Z
Jan 31, 2018 | Omron HEM-780N2 Automatic Blood Pressure...
My monitor turns black automatically after about 3 seconds. Removing the power cord doesn't work. Resetting the settings doesn't work. Turning it off and on again will make it work for 3 seconds...
LCD monitor? More than 2 years old?
If yes, then read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 20, 2011 | ASUS MNTR ASUS| LCD 19' 5MS VW193D RT...
Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
After 1 minute delay, turns on screen covered with colored spe
I just turn off the TV set, wait 30 seconds, then tun it on again and the
specks are gone/
Dec 13, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LCD 192N After 30 Min or so it starts flikering on & off.
The capicators on the internal power supply are overheating. You could get it repaired or find a way to cool the unit.
May 12, 2008 | Gateway FPD2275W LCD Monitor
We ps3
wahahahahahahahahahahahahahah .... hahaha ... ha..ha
May 02, 2008 | Sony Playstation 3 (PS3) Console
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
CTX S762A 17" LCD Monitor Logo
53 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
