Question about Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier
Amp goes in and out.
The sound in my sub comes in and out. The people who did the installation have assured me that all the wiring was done correctly. Now the one thing that could be causing the problem, they say, is my amp. How can I have service done on my amp or see if indeed that is the problem with my system.
    New Friend:
  • 101 Answers
THE BASS GETS LOUDER AND LOWER.COULD BE A VOLTAGE DROP.IF YOU PLAY AT LOWER VOLUME WITH NOTHING ELSE RUNNIG,LIGHTS,AIRCONDITIONER,THOSE THIS STILL HAPPEN? THOSE YOUR FRONT HEADLIGHT BLINK WHEN AND LARGE BASS NOTE IS HIT?R U USING A CAPICITOR INLINE WITH THE BATTERY,I HIGHLY SUGGEST AMPS THEAT PULL DIRECTLY FROM BATTERY CAN CAUSE DAMAGE TO THE IC IN THE ALTERNATOR.RATING PLEASE ,GIVE MORE INFO
Posted on Jan 29, 2008
6ya staff
SOURCE:
2009 Jeep Sahara sub woofer not working
if the wires are connected then you ether have a blown amp or sub. try hooking up a diff speaker to the wires if it works your sub is blown. if it doesnt your amp is blown
Mar 13, 2013 | Audio Players & Recorders
My amp stays on but the sound cuts in and out. Some times it takes a good 20 minutes for the sound to start coming out after I turn my amp on. Also my sub sinks in right when I turn my amp on.
Check all connections and fuses. Also make sure your speaker can handle the wattage being put toward the speakers and the OHM load. Try a different amp to see if the same problem happens. Sub sinking in when power put to it means you may have crossed the connections Positive and negative to the speaker. Triple check that your connections are correct and your using the correct wire for the job.
Jan 30, 2013 | Dual Car Audio & Video
I have this hooked up and works fine with the key on, but when i start the car, sub light, amp and sub dont come on.
You have connected it to the wrong power wire - one that is only active in service mode - first key position.
You should draw a wire directly from the battery (don't forget to add a 40 amps fuse on the wire) to the amps. If you don't want them constantly operational (you will have to manually shut them down) install a relay on the wire with the command coming from a wire from the instrument key position - second position of the key. Use a voltmeter to identify the wires.
Oct 15, 2010 | Rockford Fosgate Power 351M Car Audio...
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
Subs on stock radio
chev stock radio does not have extra plug in for sub. to run your sub, im assumed you also going to run an amp to it also. there are no addition plug in in the back, but that does not stop anyone if you know how to rig things. i would not recommend rig wires on your 2007. I would install a new radio before rigging that car; than add a sub. keep in mind most of GM radios come with stock amp built into the radio itself. If you cut the wires from the radio and wire it to your sub amp you will get nothing but distorted sound. anything sound goes to any amp need to be pre-amp in order to work properly. hope that help some
May 16, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Amp light on but no sound
either something in your amp burned up, or the audio wires going from your cd player to your amp are bad
Apr 14, 2009 | Alpine MRP-M500 Car Audio Amplifier
My subs sound distorted and dont pound right 2 12in cvr kickers and a kingwood 2 channel amp think its not wired right
Are you sure the polarity is correct on the sub's connectors? This is very important as reversing them will cause the sub to pound inward instead of out. Make sure the wires are thick enough and that the amp's + connector goes to the red(or +) connector on the sub and that the amp is grounded properly to a clean piece of metal on the car's body. This ground wire should also be as short as possible. Also make sure the fine-tuning for the bass level on the amp is adjusted correctly and that the sub's enclosure is the correct specification ie. Ported or sealed, right size, etc.
Mar 09, 2009 | Kicker CVR12 Car Subwoofer
My car amp wont come out of protection mode.
hey i had this happen to me, pull the deck out and move the rca cables to a different channel and see if that does not fix it. i blew out my sub pre out channel in my deck and had to use the rear pre outs. try this and let me know what you come up with. good luck
Mar 07, 2009 | American Pro Car Audio & Video
Something Wrong With my Fosgate 500-a2 Amp
Is the amp being fed directly from the head unit's RCA preamp outputs or is it being fed by another amp's preamp outputs? Try temporarily wiring up a speaker you know is good in place of the sub and see if anything changes.
Apr 01, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier Logo
75 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jeffery Lewis
Jeffery Lewis
colinjhought
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
