Question about Samsung TXM3297HF 32" TV
TXM3297HF Samsung TV shuts Down
My TXM3297HF Samsung just shut down, I attempt to turn it only sounds on the channel it is on with no image for about 2 seconds and it shut down again. Can you help?
Hi!! Kindly check the power supply section if their is a defective resistor or semiconductor device..thank you.
Posted on Jan 29, 2008
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Samsung txm3297hf will not start
R 818 is off value or the IHVT needs soldered or replaced.
That's what I have seen...
Call your Samsung Authorized Service Center, they have the SUPPORT of Samsung to fix these faster
Jan 29, 2008 | Samsung TXM3296HF 32" TV
Samsung 55" LED UN55D6003 Intermittently turns off and on...T/S help
DO NOT ATTEMPT ANY REPAIRS, CALL THE FACTORY PHONE NUMBER IN THE OWNERS MANUAL AND FIND OUT WHERE TO HAVE THE TV SERVICED, IF YOU ATTEMPT ANY REPAIRS THEY WILL VOID THE FACTORY WARRANTY. THIS IS CAUSED BY AN ELECTRICAL FAULT INSIDE THE TV, IT SHUTS DOWN AS A SAFETY FEATURE TO AVOID ANY FURTHER DAMAGE.
Dec 06, 2011 | Samsung UN Televison & Video
After tv is on for awhile and gets warm picture freezes but sound continues. after shutting down for quite awhile and turn it back on it works
analog board is most likely cause. Especially if you cant shut it off or change channels when it freezes.
May 28, 2011 | Samsung HL-S4266W 42" HDTV
Where is the lamp door cover located
Hi, there is no lamp door and it doesnt have a lamp neither since your tv is a CRT (Cathodic Ray Tube), only DLP's and LCD Projection TV's, For this issue you will really need to consult it with a Repair Center, CRT's are very frindly to fix, and it could be a issue on a small component if it is it will be very cheap to fix.
Jun 26, 2009 | Samsung TXM3297HF 32" TV
Samsung 19" LCD TV Freezes Image and Restarts Itself
I agree with Samsung. Tuner issues can be problematic. Since it's only a 19 incher, I'd just buy a new one!
Apr 11, 2017 | Samsung LN-T4665F 46 in. LCD Television
Samsung TXM3297HF shuts off after 2 or 3 seconds
Usually means your TV's lamp needs to be replaced. I'd need to know the sequence of blinking to really determine this.
Nov 27, 2008 | Samsung TXM3297HF 32" TV
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
50 inch samsung flat screen television
fan # 2 is having problems; maybe missing voltage or broken fan
good luck
Sep 10, 2008 | Samsung TXM3297HF 32" TV
Samsung TXM3297HF 32" TV Logo
114 people viewed this question
Jerry Greenberg
Jerry Greenberg
