Question about Janome Mini Compact
Looped bottom thread
I have tried every thing that is suggested and the bottom thread is still looping any ideas. It was working fine then started looping the thread
  • 3 more comments
  • jeannejac Feb 01, 2008
    I am having the same problem and so frustrated! Worked fine a few times, and now can't do a darn thing- I've rethreaded, respun the bobbin, changed the needle.....am out of ideas! CAn move more than a couple of stiches and it is totally all looped and messy on the bottom........
    anyone here that can help??
    Thanks
    Jeanne
  • jeannejac Mar 18, 2008
    had no luck, so I sent the machine back to thee manufacturer for repair
  • nettenette Apr 05, 2008
    After sewing over 60", the bottom thread started to tangle - now we can't get the top thread to pick up the bottom thread. Looked at manual, carefully checked the top threading and bobbin threading. Still won't pick up the bobbin thread.
    Also the first attempt to zigzag was unsuccessful - would sew mostly straight and then would throw in a zigzag or two.
    What's up?
  • feedyoureye Nov 30, 2008
    ...sewed about 36 inches, then cut the thread...started to sew a short section, and the thread started to bunch up under the needle plate and stopped the needle from working.... It seems that the same mecanism that pulls the thread up through the opening with the  needle thread is gathering up loops of thred under the needle plate....
  • Anonymous Mar 17, 2014
    thread loops on bottom
I have been having the same trouble--I took this in to a shop and was told it would cost $80 to repair with no warranty on the repair since the machine is all plastic. I think my bobbin tension is too tight but there is not a separate bobbin case, just a plastic space to drop it in.
Posted on May 14, 2008
  • 106 Answers
Sorry I missed your problem, I have just signed up on here to help with problems like yours.
Thread looping underneath the cloth is a bobbin tension problem.
Folks in general are not aware that in addition to the top tension being set correctly so must the bobbin tension.
It is impossible to explain how to do this you need to be shown. However it should be explained how to do it in your manual.
Posted on Apr 02, 2008
Singer 328K is jamming.
Most likely there are jamming threads at bobbin room under the machine stepping pedal, try to dismantle it to get rid of these threads.
Sep 22, 2017 | Singer Sewing Machines
I have a HV Designer SE and the top thread loops BIG (+1" loops) on the bottom and jams up. It looks like pretty normal stitches on the top, but it isn't good underneath. The loops get tangled up and the...
try these suggestions
new needle
check to make sure that the top thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case
the machine could have a timing problem
I suggest taking the machine tp a different repair shop next time,
when you take the machine in 5 times and it's got the same problem, it's time for a different repair shop..
Oct 18, 2013 | Husqvarna Sewing Machines
Hello dear
have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Jul 25, 2013 | Janome Sewing Machines
Singer 2517c. When sewing, the bottom stitch is using to much thread, excessive amounts & the stitch isn't tight. I've tried all settings & have used a new bobbin. I'm at a loss......
Your description isn't very clear. When you say the "bottom stitch is using too much thread" Do you mean you see lots of loopy threads on top of the seam? Or do you mean you see loops on the bottom under the fabric? If your loops on the bottom, that means the top tension is too loose, you've not remembered to put the presser foot down, you have not threaded the top thread properly... Start by rethreading carefully with the presser foot UP. Then do a test stitch, remembering to put the presser foot down. If you still get loops underneath... tighten the tension.
If your loops are on the top of the fabric. loosen the top tension... then do a test seam... and if you still have loops loosen again and repeat. If you start to see loops on the bottom... tighten the tension a bit.
Good luck
Dec 30, 2012 | Sewing Machines
Bottom thread from theh bobbin is in big loops.
Problem with Brother CS-8150 Computerized Sewing Machine
bottom thread from theh bobbin is in big loops.
I have a CS-8150 as well -it was fine until I decided to clean the shuttlecock and I thought I had put it back correctly. However, it was after replacing the shuttlecock in place that my bobbin thread was making big loops and no matter what tension it kept doing it. So I removed everything out of the bobbin area. Cleaned and made sure that the shuttlecock was exactly in place as per the manual. Guess what it does not make big loops any more.
Just a suggestion.
Sep 09, 2011 | Brother CS-8150 Computerized Sewing...
March 12, 2009 kenmore 385.17922 sewing machine ***this site won't let me ask a question - because it doesn't have this sewing machine in it's PRODUCT LIST...but i'd still like to ask the questions, and...
Dear VeeVeeV,
when I've had that problem it was due to incorrect threading of the top thread. Sometimes it "jumps" out of one of the thread guides, particularly the round one with the tension spring. The bottom thread looping & the machine not sewing is my first clue sometimes that it's done that. good luck, Georgia
Mar 12, 2009 | Singer 3116 Simple
Top thread tension tight
March 12, 2009
kenmore 385.17922
i have started using my machine again (after several years) and am doing patchwork.. all has been fine, and suddenly the bottom thread (bobbin) is looping. i've adjusted the tension nob from 4 (where i had it) to 5...back to 4.. 41/2....3 1/2....5 1/2... on and on and the bottom thread still keeps looping.
i've read and re-read the manual...and the only suggestion it gives is to adjust the tension button.
it's not working...... what else can i try??
thanks
eva
Mar 11, 2009 | Kenmore Sewing Machines
Bottom thread is very very loose during stitching, looped up
Looping on bottom:
Great description, that helps a lot. Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Kent581
Mar 03, 2009 | Husqvarna Viking 1
My bobbin thread is making big loops
Bottom looping says upper tension problems (too loose). Rethread it making sure the presser foot is up so the thread is inbetween the tension discs.
Dec 11, 2008 | Bernina Bernette 75
Janome Mini Compact Logo
181 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
