Question about Hitachi 43FDX01B TV
Hitachi ultrasound hd
Double vision with red line at bottom
  • ricardo369 Jan 29, 2008
    were is the convergence board located
The convergance board is the one with the convergance chips mounted on them. The convergance chips are the ones I have explained in detail on my solution report .
Hope this helps.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 30, 2008
    Novelist:
    Champion:
  • 211 Answers
It sounds as though you have a convergence problem. This problem is normally a convergence chip ( there are two (2) of them on the convergence board )
If you intend to correct the problem yourself, always remember to practice precautions by unplugging the tv before removing or servicing the set.
To change these chips, carefully follow these tips . I do suggest you change both chips as I have found that when one goes bad, the other one is on the way out also.
Remove the bottom back cover by using the proper screw driver or nut driver. usally a 1/4 inch nut driver or a phillips screw driver is all that's necessary.
When you have the boards exposed to view, notice on the left center of the convergence board ( the convergence board had 2 large ( large being 3X4 inches) chips next to each other. These chips normally are marked with number like STK 3020, STK 3050 etc.( I don't know the exact number on this perticlar set but they are all about the same ) They usally have about 15 pins ( wires ) coming from them. May be 12 or 18 but normally 15.
This board needs to be removed to change the chips, so remove any screws that mount the board and disconnect each wire connected to the board. ( NOTE : I normally mark each wire with some kind of a color code with permanite marker pen as to know exactly where to reconnect the wire to eliminate any mistakes )
With a soldering iron ( normally one of about 25-40 watts works well ) and some de-soldering wick ( can be purchased at most electronic parts stores or Radio Shack ), remove the chips.
Clean all the connections after taking the chips loose from the heat sink ( the heat sink is the aluminum plate the chip is screwed to ). Apply an ample amount of heat sink compound ( silicon grease it is sometimes called) ( can also be purchased at Electronic Parts Store or Radio Shack ) to the back of the heat sink and reinstall the new chips ( make sure the new chips are of exact numbers as the old), being extra careful not to bend the pins. Solder the pins being extra careful not to jump solder across any connections.( if you happen to apply too much solder and do in fact jump lead across the connections, simply use the de-soldering wick and remove any excess solder ).
Reinstall all the wires and screws to the board ( double check for mistakes ) and turn the set on, checking for the correct convergence. You'lle need to do a quick convergence with the magic focus switch after warming the set up for appr. 20 minutes. Reinstall the back of the set.
The set should work fine.
I do hope this helped
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 29, 2008
3 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: hitachi ultrasound hd
voltages to IC's There's a shielded module near convergence IC's It could be bad too. Check voltages to It.. I had simular problem /replaced IC's did not fix..Replaced module & did convergence.. TV was fine so try this 1st k
wyoed1
  • 211 Answers
Ed
NC Electronic
Mills, Wyoming
Double vision means the tv is out of convergence and the convergence board will need to be repaired or replaced.
thanks for using fixya.com please do rate this thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Feb 10, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Hdtv that has double vision
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi Projection TV 57F500A red looks double.
You need to replace both of the convergence IC's and any bad resistors around them that protect them from damaging the power supply.
This repair can usually be done in the home and takes about an hour; I have done hundreds of them and now is a slow time of year for TV shops; look around if you are not able to do this repair; you can buy the chips on Ebay for less than 15 dollars for a pair plus shipping.
This is a very common problem in projection sets.
If this has helped you give me a vote here as I do this for free. If you have questions or need help:
etower.766@netzero.net
Aug 23, 2009 | Hitachi 57F500 57" Rear Projection...
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Red line
Convergence ICs STKs replace both of them If they are STk392-110s up grade to 180s better ICs They are big black chips order parts at Electronix Parts 1-800-223-3205 you will need to also buy heat sink compound to put on back of new ICs.
Dec 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Red and Green double vision
Depending on the age of the unit. You have a convergence problem. This is not uncommon. You can contact a servicer thru this homepage and have them look at it. Convergence issues could be anywhere from 200-350 depending on your area.
Dec 17, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Red blog and bubble vision, after lamp change.
YES, CHECK WITH HITACHI THEY ARE REPLACING SOME OUT OF WARRANTY LIGHT ENGINES
Dec 11, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX01B TV Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
