Question about Sony Cyber-Shot DSC-S500 Digital Camera
Black screen when i turn my cam on i can only see a black screen and can only take black pictures. after reading some of the other questions it looks like it might be the backlight or screen. how can i know that this is what it wrong?
  • 47 Answers
If the camera is taking photos that are pitch black, and you cannot se anything, then it could be one of two things. 1) your backlight AND lcd are damaged/detached (if it was white that would mean the backlight is working) or 2) the CCD (like film for a digital camera) is damaged. If you can see an image, but it is VERY dark, then that would indicate a backlight error. There are 2 ways to test this. 1) take a picture and transfer it to your computer. If you can see the photo you took on your computer then it is a backlight/lcd problem. or 2) under the rubber where you usually plug the usb in, there may also be a plug that looks like it would fit a headphone jack. There should also be a cable with red/white/yellow on one end and a headphone looking plug on the other end, that came with the camera. You could connect this to your camera and to a tv and you should be able to then see what the camera sees. If you can then it is a backlight/lcd error. If you can't see anything, make sure the tv is on the right setting and that the yellow plug is fully inserted. If you still can't see anything then it is probably a ccd error, in which case you should contact sony.
Posted on Jan 30, 2008
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
So i have a Sony Computer it's not a lap top, Its like a desktop. and it has a built in web-cam and microphone, The web cam did work for a while then one day it just turn black. It says its working right...
I have found that the installed web cams on most units are inferior and a external USB cam has better quality in sound and picture and are very cheap and can be pointed in any direction and even used to copy photos your screen or documents , so if you are a frequent cam user buy your self a USE cam for $50 or less
Oct 28, 2017 | Sony Cyber-Shot DSC-P150 Digital Camera
My Canon zr85 camcorder turns on, but the screen is black. All the menu stuff shows up, but no picture. When I press play to look at photos, those show up. When I try to shoot images, it's all black.
its look like the opitcal block do not operate
look to canon web site if your cam are not on the recall list at (canon.xxx/support/service)
hope that help you.
Feb 18, 2010 | Canon ZR85 Mini DV Digital Camcorder
Our C613 is not reading the memory card when it is turned on. It goes straight to built in memory which only holds 12 pictures. What do we need to do??
Pls. check that the "lever" on the memory card isn't set to black the reading of the card.
Go into Menu, Cam settings and AUTO or internal: Press OK for Internal.
NOTE if the cam. cannot read the card it will automaticly go over to internal memory.
Good luck
Nov 27, 2009 | Kodak EasyShare C613 Digital Camera
Screen turns black after taking a picture
If the cam has never been dropped i would suspect a software issue.
Check the manual and see if there is a master reset, if so try it and see if that solves the issue. if not i would tend to think you will need service.
As i doubt there is little that can be done from the outside of the cam to
correct the problem.
Aug 09, 2009 | Kodak EasyShare M1033 Digital Camera
Procedure to downl;oad pictures directly from
install software from your canon CD
plug in usb in pc and in the cam, turn on the cam and software will do the rest, just follow the questions on screen
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Don't worry you dont have to buy a new camera :) When you press the menu button there should be an options menu. look around for the "effects" options or something along those lines. There is a black and white mode on the camera, my guess is that it turned on somehow. All you gotta do is turn it off.
I hope that this helps, feel free to ask more questions. I have a jvc video camera just like this one, so if need be i can just look at mine!
Jan 15, 2008 | JVC GR-AX940 Camcorder
Scren split into 4 and in black and white.
Fergal0,
I am wondering if you have accidentally puy your cam in one of those fun modes like the ones that distorts the picture or turns it into 4 color pictures etc. I don't know what it is called on your model but the menu for this is called video effects. I know where it is on Logitech quick cams but not for yours. I suggest you just try looking at these setting options and see if you can make it change to something else and if so then you are in the right place and just have to find how to turn this off. Let me know what kind of camera you have and what kind of menus you have available if this does not give you a good hint.
Dec 02, 2007 | Logitech QuickCam Pro 5000 Webcam
There is no picture on my web cam just a black screen
have you uninstalled the webcam and re-install the drivers sa when you install some programs they overwrite the dll files in windows directory and goto the web and update the drivers if they have them on the manufactures web site. hope this goes well.
Aug 17, 2007 | Veo Stingray
Black Screen
camera ccd is / has failed - also possible , lens iris is stuck closed ( on monitor , can see very faint snow noise against black background - check if iris opens , by shining penlight into lens );
May 03, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-Shot DSC-S500 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
