My Maytag PAV2300AWW Performa is noisy on spin cycle
My maytag PAV2300AWW is really noisy on spin cycle.
  • 3 more comments
  • billj40 Mar 14, 2008
    My Maytag PAV2360AWW Performa is unbalanced during spin cycle, tub hitting sides. Load is balanced and don't see any problems with springs.
  • chipmonk5 Apr 05, 2008
    I have the same issue with my maytag, but I think it is the back right balancing arm sticking
  • btw21259 Feb 09, 2009
    I thought the load was just unbalanced, but it was even off kilter with just 2 socks - one on each side!
  • Anonymous Mar 16, 2014
    maytag 5840two slow noisy spin
  • Anonymous Mar 17, 2014
    Model PAV2300AWW
  • 5,911 Answers
If you are talking about a loud sqeaking noise, this is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). However, if the snubber is worn too much, or if the brake assembly is worn they must be replaced. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
You can find all your parts and information at repairclinic.com. I am not affiliated with the website. I am merely recommending them because I have used their service before. Plus, they use the same repair parts as your major appliance repair companies, but at a lower cost.
The parts required to make the repairs aren't very expensive, but the tool required to do it IS. Also, if you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good abpout providing the necessary instructions with their parts, but this is a bit involved.
Post back with comments and let me know if this helps you.
Posted on Jan 29, 2008
    Problem Solver:
  • 11 Answers
Every time I use my washing machine I see some white stuff on my black clothes. I even got a new washing machine but the problem is still there. Today I washed my clothes and all the black clothes had some white stuff on it so I had to rewash is by hand. What can I do for that?
http://www.affiliate-talk.com/
Posted on Jun 01, 2010
The best thing you can do is just to toss the washer out the door and buy a new one. I think this machine would be around ten years old, or is this a very brand new one?
If it is old, get a new front loader washer, they are cheaper in usage, water and hydro, and your wash will get claener with smaller amounts of washing powder.
Posted on Jun 23, 2008
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Maytag performa PAV2300AWW will not spin but sounds like it is.
I think you have guessed it right. There is probably something stuck between the tubs. I have seen this caused by a lot of things. You should look for things as small as coins, shirt buttons, cufflinks etc., Also I advice you not to turn on the machine until the blockage is removed.
Good Luck,
Sai.
Mar 15, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
3,347 people viewed this question
Top Washing Machines Experts
