Question about Samsung PCK520R TV
Color is going out
The color looks weak and not clear like it once was, how could this be fixed.
  • discorowe Jun 09, 2008
    My color has faded. I use the menu screen to adjust the color, brightness, contrast but the picture still looks clouded by yellow. What are some likly causes for this faded picture. If it is the tude please let me know the cost and where to order one
    Billy Rowe
    (334) 221-2895
  • kennethelsme Mar 03, 2009
    yellowish glaze very bright hard to define color.
    Problem Solver:
  • 9 Answers
Kindly see the color cntrol and try to adjust it. at the front of ur monitor....
Posted on Jan 29, 2008
Lg 56dc1dab dlp projection tv is now in black and white? The lamp indicator has been on for a while. Is the colour gone due to further damage or can we replace the lamp and fix the colour?
lamp going out should not cause color to go out. I would check all connecting cables at both ends to be sure that is not the color issue.
Be sure you did not accidentally turn color down in trying to adjust video controls due to weak lamp. Then replace the lamp.
Jul 24, 2014 | Televison & Video
Help, color and clarity is weak what do I do?
You don't give a brand of printer, but some printers software let you go into print properties and set the printer clarity and darkness. Maybe yours is set light, because of someone trying to conserve ink. Please rate my answer so I get points for it.
Jan 22, 2012 | Office Equipment & Supplies
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
the circuit that maintains voltage to the color for the red color is weak and has possible weak or defective parts that need replacement. In this case it could be the high voltage tranformer or regulator at the color compensator circuit that maintains the balance of the color or color pins at the CRT tube. They are becoming weak and the tube may need replacement.
Jul 19, 2010 | Acer AC 713 17" CRT Monitor
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
Picture flashing, weak color. whenflashing stops
I have the same problem with a WD 73732. After about an hour fleshtones go blue / purple, and picture flashes. I gutted the set, and ran it on the bench, and found that a sensor on the color wheel (a small external board), acts up when it gets hot. Cooling the board fixed the picture. I'm going to try to find a replacement part, and then make vents in the color wheel cover so it doesn't get so hot in there.
Jan 22, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi HD 50" rear projection tv is only showing picture in black and white. What is the problem?
Is sounds like to need to go to SETUP and set the unit to color. Also, weak signals will cause the unit to switch to B/W. Try using OTHER inputs (like DVD) to see if you still have no color. If no color, it could just be a SETUP problem...or..(ugh!) you have lost your color wheel or related circutry. (no easy fix)
Jul 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No clear color
i had the same problem a year ago / this is not somethin you can fix by yourself
you shood get your camera to a laboratory that repares sony's camera because there is some chip they need to replace - if i recall somethin likr color mannager\spliter i don't have the wright words in english for this
Mar 09, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Coffee is coming out weak
Make sure you are not using the paper filter and the permanent filter at the same time. Make sure the chute undernetah the grind basket is clear of grounds, moisture.
Sep 01, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Epson CX6600 lines on standard color printing
See my previous posts about intensive underhead cleaning. If the standard cleaning cycle in the printer driver/control panel does not clear the nozzles then following the info in previous posts about underhead cleaning should get you going again.
May 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Televison & Video Logo
234 people viewed this question
Jerry Greenberg
Jerry Greenberg
