After I configure these settings and restart the camera, it asks me to input the settings again!
My battery is fully charged and the camera seems to work fine besides the issue I mentioned.
Have I bought a faulty camera?
Perform the reset operation to initialize the camera’s
setup (page 136). After that, configure each setting. If
the language selection screen does not re-appear
when you turn the camera on, it means that the
camera’s built-in memory management area has been
restored. If the same message appears after you turn
power back on, contact your retailer or a CASIO
service center.
Main support number800-962-2746
http://www.fixya.com/support/p504372-casio_exilim_ex_z1000_digital_camera/manual-19919
The camera does not have a separate battery for the clock. If the date and time setting screen appear when you turn on the camera, it means that battery and USB cradle power was cut off for about 30 hours, which causes the date and time settings to be cleared.
If this is not the case in your situation then,yes, your camera is defective.
Mybe you should reset the camera, remove all the battery and fix back after 10 minutes or more then start the camera and do settign again.
Configuring regional settings
You can adjust regional settings for number, currency, date and time formats to match those used in your country.
1. Tap Start > Settings > System > Regional Settings. 2. Tap the Region, Number, Currency, Date and Time tabs to view information for your region. Adjust any if necessary.
3. Tap OK to confirm and save.
Try this:
