Question about Jenn-Air JGR8875QDS Gas Kitchen Range
F-8 on my jgs8750ads
I have a jg58750ads that has f-8 code problem it continually beeps. do I need to replace the touch pad? if so how hard is it? Was there any recall on this?It seems a lot of people have had this same problem.
  • Anonymous Oct 03, 2008
    I've had this problem repeatedly, and Maytag has replaced the console twice already, and it's happening again. Ours is 2 years old, and the problem started after 1 year. Just reported the third instance of this happening - was told "sorry", but I asked for a manager/supervisor. At that level, Maytag offered its "Repurchase Incentive Program", which is 15% off the final price (including any sale prices) of a new stove under the Whirlpool family, which now includes Jenn-Air, Maytag, etc. Apparently if a repair person deems it "unrepairable", it may be considered for replacement, at a pro-rated value (taking into account depreciation), which may just result in a check being cut. We'll see how it works out.
  • donnyl Jan 07, 2009
    Replaced the ERC but that's not the problem at $200.00. Talked to jenn-air after the costmer service did not no the answer .Told them to connect me to there engineering staff .They said they could not do it. Then all of a sudden they told me it was touch control pad short. F1-8 fault code( shorted touch control.) Jenn-air has this problem right along and kept selling these products and did nothing about it. They said they knew nothing about it. I said try looking it your order supply for touch control pads. DON'T BUY JENN-AIR. BUY A RANGE WITH KNOBS.
  • 5,911 Answers
On some model Jenn-Air ranges F8 indicates a failure of the Electronic Range Control (ERC). On some newer model Jenn-Air ranges F8 indicates a "shorted meat probe alarm" which could indicate a problem with the probe sensing jack and/or sensor. If you do not have a meat probe, then I guess this can be ruled out. My experience tells me, however, that this is a problem with your ERC. Just to be sure, all major appliances come with tech sheets. These are usually placed in a convenient area inside the appliance so repairmen will have a reference to work with. On ranges, this tech sheet is usually located inside the electronics console, or on the back of the range somewhere. It should have a list of fault codes and possible diagnostics procedures as well. If you wish to replace the ERC, the part number is 1035401 and costs approx. $160. I hope this information is helpful. Post back if you have any further questions/comments/concerns.
PS I could not find any information about a recall on this product by Jenn-Air. In your owner's manual there should be contact information for consumer affairs or customer service. They may be able to provide you with more definitive information on this.
Posted on Jan 29, 2008
  • 52 Answers
F8 Analog / Digital problem Replace clock (ERC).
Not hard to replace, just make sure you unplug the appliance first. I can not tell you about a recall, try contacting customer service with that question.
Jgs8750ads I replaced the touch board and short sensor and still receive F3-1 code
Typically this code is cause by a bad thermal sensor or thermal fuse. Might want to check wiring for continuity, resistance, open shorts leading from the sensor to the control panel using a multimeter.
Nov 16, 2011 | Jenn-Air JGS8750ADS Gas Kitchen Range
Continuous beeping with F7 fault code. What do i need to replace, the touch pad or controller?
Hello, Thank You for using FixYa. I will be helping you today.Turn off power unplug ribbon cable from touch pad to control turn power back on and if after an hour no error code replace touch membrane if you get a fault replace control (clock Erc)
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Jenn-Air Ovens
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 | Ovens
I have a Model # JGS8750ADS. The beeper started going off and F1 -8 scrolled across the touch pad screen along with the 800 #. They said get a repair man. I want to fix it. I install new Clock, w/harness...
Sorry to read about your problem, I hope this helps you out.
They problem you have is ether the defective clock or keypad..since you replaced the clock, it must be the keypad...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
Jenn air range model # jds9860acp fault code f1
i need your help someone please my jenn air oven does not heat up quickly at all it takes for ever to get to 250 i have replaced the sensor and the touch pad still no fix can anyone suggest anything else
Nov 09, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
Beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 03, 2009 | GE Ovens
Control beeps continuously. Display shows F1. Started when oven had not been used for a long time. Pushing oven and timer off buttons resulted in 10 seconds of silence before beeping resumed. Same for...
Usually, This means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 28, 2009 | GE Ovens
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
468 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
