Question about Video Cameras
Canon 8mm video camera E06 no audio
I am using a Canon 8mm video camera E06 and while reviewing my tapes I am not hearing any audio. How do I get the audio to work?
4 Suggested Answers
larry james
  • 286 Answers
A jvc right? need a model but if it's what I think it's one of two things.either the belt came off the capstan motor or there are 3 connectors along the bottem edge of the main board.
Posted on Sep 18, 2007
SOURCE: Sony Digital video Camera Recorder DCR-PC6E/PC9E
I am new to this computer sorry, I am trying to transfur Sony 8mm tapes on to DVD RW disks via the computer, thank you for replying.
Posted on Sep 04, 2008
  • 423 Answers
SOURCE: Transfering 8mm video tapes to dvds
Hi there. You need to transfer your videos to your computer and then burn them to DVD using a program like Record Now, or Nero. You should be able to get this from Best Buy, or you can get it online from their websites. If you have any other questions, let me know with a comment. Thanks for coming to FixYa.
Posted on Mar 03, 2009
  • 154 Answers
SOURCE: canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Posted on Mar 27, 2009
0 characters
1 Points
Video Only, and Best Buy will most likely have 8mm tapes. Walgreens and Radio Shack should also carry them. If the only tapes you can find are labeled Hi8 or DV8, you can still record on them with an 8mm camcorder.
May 16, 2011 | Canon ES50 8mm Camcorder
8mm video tape to vhs
If you wish to transfer the 8mm to VHS you will need to connect the camera to a VCR VHS recorder.
Use the red and white audio connectors and yellow for video to connect the two devices.
Feb 12, 2011 | Canon Video Cameras
Though 8mm filming was and still is the best safest way to make movies Sony have stopped producing 8mm tapes, I use the brand new Digital 8 tapes on my brand new Sony camera, would never dream of going over to Hard drive/SD card/DVD recording cameras as the image will not last as long as it will on 8mm tape.
Also the 8mm cameras are much better made than anything since 2006.
If you type 8mm movie tapes in your search engine you will find 100's of firms still selling your tapes, they will help you choose the right one ok?
May 25, 2010 | Sony Handycam CCD-TRV22 Camcorder
I have a sharp 8mm camcorder. i have a tape that just plays the audio and not the video. HELP
there is differnt quailtitys in the 8mm tapes, i knwo there is a real HQ one that if its used int he standard 8mm cam corder you will only get audio from it. hope this helps in some way.
Nov 30, 2009 | Sharp Viewcam VL-AH151U Camcorder
No sound records sony dcrtrv530
I reviewed the owners manual to your camera.
On page 126 it says this:
1)The stereo tape is played back with HIFI sound set to 2 in the menu settings.
Set it to STEREO (see page 79)
2) The volume is turned to a minumum.
Press Volume + (see page 27)
3) Audio Mix is set to ST2 side in the menu settings.
Adjust the audio mix (see page 79)
If one of those 3 options doesn't work, try using an 8mm tape head cleaner.
Jun 15, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
FUJIX-8 F60wide eats tapes when I rewind
You should e able to use any head cleaner, as long as it is the right size for you camera, but that is deffinitely your problem.
Feb 13, 2008 | Canon XL1S Mini DV Digital Camcorder
No video or audio in playback mode
I Had a similar problem with my 8600. Most likely the camera
is also no longer recording. There were two problems I found,
either one could have caused the problem. 1) the 8mm tape was not
actually moving through the record/play head. With modern cameras. there are no indications that the tape is actually moving.
2) the record/play head is dirty. What I did was remove the
side plate that covers the tape cassette to allow me to verify that
the tape was moving properly. After that, I removed the tape, removed the battery, and used isopropyl alcohol and a q tip
to clean the head. I imagine there are cleaning tapes that one
can buy to do this as well. though I doubt they work as well as
a q tip. THere are two screws that hold the cover on.
Dec 15, 2007 | Canon ES8400V Camcorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
138 people viewed this question
Top Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Video Camera Expert? Answer questions, earn points and help others
