My hard drive is no longer showing up on my computer. When I plug it in, it trys to install new hardware. This is the same across several computers. It worked fine one day, and the next day it started doing this. Thank you.
The time it takes for a Dell Latitude E6400 to complete a diagnostic boot can vary depending on several factors, including the specific hardware configuration of the computer, the number of diagnostic tests that are run, and the condition of the hardware.
Typically, a diagnostic boot on a Dell Latitude E6400 can take anywhere from 5 to 20 minutes, depending on the specific model and the complexity of the diagnostic tests.
The diagnostic boot process on the Dell Latitude E6400 starts with a pre-boot diagnostic test that checks the basic functionality of the computer's hardware, including the memory, hard drive, and keyboard. This test typically takes only a few minutes to complete.
After that, the system will run a more extensive set of diagnostic tests which include PSA (Pre-boot System Assessment) and ePSA (Enhanced Pre-boot System Assessment) . These tests take longer to complete and check the more in-depth hardware such as the system board, processor, and other internal components.
You can also run an extended diagnostic test that checks all the hardware components of the computer, including the memory, hard drive, and other internal components. This test takes longer to complete and is typically used when the computer is experiencing hardware-related issues.
Please note that the diagnostic boot process can take longer if the computer is experiencing hardware-related issues, and if the computer fails the diagnostic tests, it will stop the boot process and show an error message.
Whilst that can be resolved by reconfiguring the Operating System setup - the simplest way that normally resolves such problems is to just unplug the USB lead and replug, when the computer will normally "find" the new hardware. if not, try plugging the lead into a different USB socket. If you have no spares - an inexpensive USB extender can be obtained to provide several USB ports from one of the main USB ports on the computer. I would also advise (beneficial for this and other installed drivers) to get the excellent free IOBIT Driver Booster - it really is free, not like all other free-download driver offerings where you download, install, do a scan and then find you have to pay. In addition, this actually finds missing drivers, as well as updating those you have. Can thoroughly recommend. Just remove the two gaps in following link - as I think this website would otherwise delete full links. http:// www. iobit.com/driver-booster.php
Some usb drives - i.e pen drives - bring up the same message when they are inserted into a usb port. Windows usually installs the necessary software from within your computer. Other pen-drives are plug and play. Much depends on the operating system you have and the age of the usb pen. It's probably just a question of getting updated drivers for your desktop hard drive. Right-click on the 'my computer' icon. Choose 'properties' Then choose 'device manager' or 'hardware'. Locate where your desktop hard drive is listed and open it. Then choose 'update driver'. Your computer should then search itself for updated drivers (which it won't find..) but it should also ask you if it can access the internet to search for drivers. Alternatively, go to a website where you can download drivers yourself. Try http://www.iomega.com/support/documents/10425.html Be aware that your desktop hard drive is now quite old. It won't last forever .. If you've got important stuff on it consider buying a new desktop hard drive and transferring everything to the new one.
As the Windows installation is installed on the first computer hardware configuration and now it is moved to another computer hardware configuration, ie another computer. It will not work as Microsoft prohibits moving/changing hardware configurations to the extent of another computer system.
In your case you will have to return the hard drive to your original computer and then backup your files. Then this hard drive needs to be formatted, all data will be lost. Then the hard drive can be install in the better computer and a fresh installation may be performed. However you will need to read the terms and conditions of your Windows LicenseAgreement to see if this is indeed possible.
With regards to the DVD drive, it needs to be connected on the IDE2 port, right at the end of the IDE bus/ribbon. There are 3 positions a longer length and 2 shorter lengths.
Long side plugs into the mainboard, the middle one is left open and the shorter end one is plugged into your DVD Drive.
Ensure that the jumper located between the power and IDE port of the DVD drive is set to the Master Position. The details can be found on the label on top of the DVD drive.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
First check your usb port of computer and usb csable are working fine.
Then go to my computer proeprty then hardware then device manager then uninstall all usb drivers then restart the computer then check.
neither, the new disk is in need of a driver to operate it it should be in the box with the drive for some reason it is not seen as plug and play. you could delete it from system in device manager and try plugging it in again. Watch the bottom right of screen FOUND NEW Hware.... Installing new hardware Your hware is ready to use should then show. if that dont occur then the problem is an incompatible new hDD
I have had a similar problems with external drives that only plug into a USB port (no ext power adapter). It is very common that the power supply fed through the USB port is inadequate to power an external hard drive. Some enclosures have a external A/C input to resolve this. Also, some computers (motherboards) only have a select number of USB ports that are powered. Since this device is detected by your other computer and not on the new one, my next attempt would be to locate a USB hub with external A/C power. There is a good chance that this will resolve the problem. By the way, when you plug in the drive does it spin up?
How would I go about doing this?
