Question about Proview HX303 30 in. HD-Ready LCD Television
Proview HX303 30 in. HDTV-Ready LCD
I have a problem. I can turn the power on by the switch in the rear and the indcator light in the front is orange. When I turn the tv on the light turns green , then the screen is black then the picture comes in then goes black
  • bsteets Jul 14, 2008
    2 yr old tv - black screen.
    The tv is attached to Verizon HDTV Fios. Was working well - then BLACK!
    I have tried cutting off power to the box & the TV (usually a verizon fix) - Dunno what to do........
  • 3 Answers
Inverter board is tripping protective circuit. Check Caps!!! or Ballast's.
Posted on May 30, 2008
    New Friend:
Cuando se enciende se cierra la pantalla y no da audio por lo k se queda oscuro
Posted on Aug 22, 2011
6ya staff
SOURCE:
What does a orange not blinking indcator light mean?
For your TV the power light will be red when the TV is turned off using the power button on the top of the TV. Press the power button on top of the TV if that does not work then try turning the power off at the power switch on the bottom of the TV then turn it back on after a minute ior so and see if you can turn it on using the power button.
Aug 05, 2014 | Protron PLTV-37 37 in. LCD Television
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
When switching tv on it shows vertical lines and fades away
This can be an indcation two things 1: a defective focus/screen block or 2: a defective CRT if the lines are of one color then it is that color CRT. in any event you will need to have a tech work on this, doing this repair yourself can be very dangerous for you and the set.
Jan 19, 2011 | Sony KP-57WV600 57" Rear Projection...
Where is power button located on tv
If it is the flat screen model look at the TV, You will see a blue or orange indicator light on the front of the tv by the speakers. Put your finger over the light and the TV will come on and off. The Volume, Channel and Menu buttons are there also. They are not an actual push in "Button". Just look at the TV close to the Proview insignia. You'll see the On/Off button there!
Oct 29, 2010 | Proview PA-32JK1A 32 in. LCD Television
My LG DLP RU-52SZ51D rear projection TV doesnt turn on.
See if Lamp Fan is running it can be defective and if Fan is OK it will be Ballast Board, Call Encompass Parts 1-800-638-3328
Dec 31, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Orange light on the front of the TV
Replaced bulb for zenith e44w46 lcd but the orange light is still on how can I reset the bulb timer on my own without throwing down another 85.00 for a repair guy to reset my T.V.
Jan 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Sony Wega
Most of the time this is caused by a defective lamp. If the light blinks the number of blinks is a failure code.
Nov 12, 2007 | LG RU-60SZ30 60" Rear Projection...
Proview HX303 30 in. HD-Ready LCD Television Logo
266 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Duncan Mutch
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
