Refrigerators Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint refrigerator CTX 18G makes noise when compressor comes on. I opened the the back bottom panel and the noise went away when I unpluged the plug on the far left (as viewed from the back) was unplugged, the noise stopped. When plugged back in it still makes the vibrating noise, but a little less. Will this damage the fridge if left unrepaired.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Dec 29, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2968770
Points
24702
No. This is not affecting the operational value of the compressor at all. It is just an annoyance, at most. I would recommend to inspect the entire unit for other noise enablers, as well.Here are a few areas that will cause abnormal noises in your unit.
Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
Hotpoint Fridge Freezer makes a lough cracking / popping nose
think the door was left cracked open all day while we were at work, so it had to work to keep cold all day- and now it's making this horrible noise and not really cold as it should be. the noise is coming from the back, there are a few things that could be causing the problem. If the unit seems louder when the compressor starts, it's probably a normal sound. The compressor starts with a high pressure, but as the pressure balances, the noise should become normalized. The compressor is in a black case with no visible moving parts. It's located at the back of the refrigerator near the bottom and has wires and a bunch of tubes going to it. If it's humming, or making a steady noise, and your refrigerator is still not cooling properly, there could be a problem with one or more various components. If the compressor is making noise, there's probably no repairing it. You'll have to replace it. This is often a very costly job and needs to be done by someone with the necessary EPA certification to work on sealed systems.
Hotpoint ffp187b loud noise from appliance
Where is the noise coming from? The front, back, top, or bottom? Is it a bump, thump, bang, clang, or rattle? Does the sound happen at regular intervals or randomly? It could be the compressor bushings going bad, causing the compressor to bang around.
2helpful
Fan make noise
There are 2 things in that area that can make a noise, the ice maker,and an evaporator fan,depending on the model.The fan is an easy fix if the blade is just hitting something ,but you have to be abit mechanically inclined to get to it.The icemaker has a little motor that sometimes gets stuck in the ice harvest mode,then you just have to unstick it ,also depending on what kind of fridge you have..everything else is down at the bottom,compressor,condenser,ect. In any case you probably want to call a tech unless its old,because repairs would be more than it is worth.
1. Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
2. Take raer panel off inside freezer and check there is no ice build up which is hitting the fan
3. Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
4. Unplug the refrigerator, and listen to the back side of the fridge. The fans will immediately stop running. If the back of the fridge continues to make a noise after the fans have shut off, the sound is most likely coming from the compressor, which is located at the back of the fridge, near the bottom. If you have a compressor problem, you either have to replace the compressor or the entire refrigerator.
I have a hotpoint fridge bottom freezer and after I had filled the freezer with my shopping yesterday, it started making a shreeking noise, I thought maybe it needed defrosting, which it did, so I...
If both section are not working as required then its compressor fault.The noise you noticed must be from compressor related parts,that are fan,the motor and relay.But If freezer is getting over cold and friezed and fridge section not getting cold then Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
1helpful
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
4helpful
It's making a loud running noise
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Refridgerator make a noise every 3 minutes
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
4helpful
I am getting a loud rattling noise. could this be my compressor
Loud banging nois when compessor shuts down
The banging noise usually occurs when the internal mounting springs are weak. You cannot get to them, they are internal. This causes a banging noise when the fridge comes on or switches off. It can also happen when the starter relay on the compressor makes a bad connection and therefore the compressor does not get immediate good power causing a stutter.
1helpful
Fridge freezer not working Hotpoint RFA17
It is one of two things. Either your compressor went bad or the relay that connects to the compressor is bad. Those are the only two reason why it would not cool at all. You can try to unplug it and plug is back and and see what happens it might shock it back
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
