FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Replacing the lamp in the microwave of a Kitchenaid... (by 3 users)
posted by Arturo59 on Jan 29, 2008
I am trying to find out how to replace the lamp in the microwave on this built in oven/microwave. Nothing in the users manual mentions the bulb in the microwave. (They mention the bulb in the oven and that's a breeze) I checked the Kitchenaid site and found the parts manual and see that it's a halogen bulb and it's in the $30 range. Just need to know how to replace it. Any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Aug 06, 2008
NEFF MICROWAVE CANNOY FIND ACCESS TO RELACE THE HALOGEN LAMP
Comment by Guest, posted on Apr 20, 2008
I had the same problem.  You have to take the covers off the front of the oven and get to the space below the controls and and above the roof of the microwave.  The microwave will them slide out a little and give access to the light bulb connection.  Hope this helps. My new problem with this microwave oven is the metal spring bars in the door.  They snapped and I replaced them but they do not have the same tension to support the door when open.  I have tried to find a detail of how the parts fit together and can not find.  Anyone with suggestions?
Best Solution
posted on Feb 11, 2008
Thanks for Trying (70)
who BoB
Rank:Wiz Wiz
Rating: 82%, 49 votes
Have work on these model, but narmaly they should be easy, to help, unplug it and open the cover to see if you can figure it out better, narmaly it's a clip on stage plastic that hold it in place, The bult could have purchse I think true gooles, with there part # back track it to see if a local shop would have it. $30 was very high.
I hope this help
What About Bob
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE XL1800 1100 Watts Microwave Oven GE JVM3660 1000 Watts Microwave Oven GE JVM1350BW/WW/AW/SY Microwave Oven GE JES1358 1200 Watts Microwave Oven GE JES1384SF Stainless Steel 1100 Watts Microwave Oven GE JEM25 800 Watts Microwave Oven GE JES1289SK Stainless Steel 1000 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
I wanted to use the
I wanted to use the timer and... Answer This...
Microwave Ovens
How to stop the beeper and...
emerson microwave oven will not... Answer This...
Microwave Ovens
sharps microwave
i have a sharps microwave model... Answer This...
Microwave Ovens
does not work
does not work Answer This...
Microwave Ovens
thermador microwave from...
thermador microwave from... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
