Question about Logitech (980158) Headset
No sound,no working mic...not even showing on my voice tab in control panel
No sound, no mic working, not listed on the voice tab in control panel, cant remember if it came with a disk but i think i need a walk through of how to check if its being recognized and if not how do i get my pc to do that and then to get the thing working again if possible, pleeeeeease help me :0) <3
  • Anonymous Apr 12, 2009
    brand new, plugged it in, NO SOUND
No sound,no working mic...not even showing on my...
Posted on Dec 08, 2008
  • 3 Answers
Just a couple of questions that might help you solve your problem..
- Have you already installed the sound driver of your motherboard/sound card?
- Have you properly inserted the right color/jack of your headset to the computer?
- Have you check the volume control of the headset whether it is in mute or full volume?
If you have tried the above questions then you might have a defective headset.
To test if it is working, try playing some music & the sound recorder for you mic.
benson
Posted on Jan 29, 2008
Not voice coming & going
Hello
In control panel.Go to sound .Once there open your speaker properties then go to level tab.To the right is a list.Scroll down to mic and turn it up.
Then go to recording properties.Custom tab.Check box for 20db boost.
Mic should work now.
Sep 17, 2011 | Creative Labs CT4870 / CT4780 Sound Card
Win7 computer recognizes headset in and mic in when plugged into the front of the computer. Rosetta Stone Spanish (LA) does not show that there is a mic connected. Control panel shows that it's there. ...
what is this it's
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Apr 14, 2011 | Computers & Internet
My mic is not working
If your mic isnt working i recommend you going into control panel and go into hardware and sound, sound settings, click on the recording tab and choose the mic you have, if its not showing the list of items, right click the white part and click on show disabled devices,, that will bring down the list.. good luck
Jun 05, 2010 | HP Compaq Presario V2000 Notebook
My Dell Dimension E510 cannot pick up any voice recording from my various mic inputs. I have fiddled with volumes of each respective input (line in, rear mic, mic jack) to no avail, and when I try to use...
This sounds like you have a voice morphing program installed. A morph program is useful for distorting your voice and special effects, but it also takes over your mic controls. Go to the control panel and choose sounds and audio devices, then look for the default device under sound recording and make sure your record device is the same model as your sound device and that it says INPUT. Another problem occurs if you right click your little sound/audio icon on the taskbar and choose open volume control then left click. Do that now and choose, options, then properties. Now on mixer device, choose one that says input. The white window on the bottom of that panel will show you several devices, check mark them all and click ok. Now manually select MIC as your default sound input device and close then try again.
Mar 09, 2010 | Dell Dimension™ E510 PC Desktop
How do i connect an external microphone to my philips freevents x55. only the built in microphone is working. an externally connected mic does not over-ride the internal one?
Your default recording device is still set on the built-in mic.
In Microsoft XP...
Choose Start > Settings > Control Panel and double-click the Sounds and Audio Devices tab
Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
In Vista, choose Start> Control Panel > Sounds and click on the Recording tab.
In both instances, choose your external mic as the default.
Windows XP 1 Choose Start > Settings > Control Panel and double-click theSounds and Audio Devicescontrol panel.
2 Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
Oct 04, 2009 | Computers & Internet
Output mic not working HP Mini
First go to start menu, control panel, sound and audio devices, click the voice tab, and make sure the voice recording has something listed. If not see if you can change it to your MIC. If you get no options in this box you probably don't have the mic installed correctly. If everything appears to be ok in this go to your volume controls, click options, click properties, and make sure you have mic selected in playback sections and check the boxes in recording settings then click ok, one you do this make sure alll volumes are unmuted and turned up.
May 28, 2009 | HP Mini 1000 Netbook
I can't use my built-in mic of my acer aspire one notebook.
To test the microphone, click "start" button, then "Control Panel", then "Sounds and Audio Devices". On the popup window that opens, click on the "Voice" tab, then click on the button that says "Test Hardware". After several seconds this will bring up a test program that will show a noise level meter when you're speaking into the microphone. (The default device listed under voice recording should be "Realtek HD Audio Input".)
Jan 31, 2009 | Acer Aspire One PC Notebook
How to turn-on/function mic in my acer aspire one pc notebook?
My Acer Aspire One Microphone Isn't Working
Control Panel
Voice (tab)
Volume (button)
Unmute Mic
Turn up the level if necessary
Jan 14, 2009 | Acer Aspire One A150-1006 Notebook
Mic dont work
luis_antonio, did you try to set your mic up from within windows?
Do this, open control panel, than open sound and audio devices. Click on the voice tab, click on the test hardware button.
Follow the on-screen instructions. Do you have mic?
There is no direct connection to the board. There is a connection for a front mounted case sound & mic connector if your case has this feature but chances are if your mic does not work connected to the rear of the board it will also not work with the front connector/jack.
Let’s check two other places first. While having opened the sound and audio devices window, click once again on the Voice tab if not already opened. Notice the Default device, (the name of the device). Click the Audio tab listed there is a Default device, (name of device). They should be named the same. Click cancel to close that window. Than open the system icon. System Properties will open. Click the hardware tab, than click the device manager button. Scroll down the list to Sound, video and game controller. Click the + sign & all the audio devices will open for you to see. Do you see a yellow ! point? If yes your sound device software needs to be re-installed. If no & you see a device named ADI AD1986A SoundMAX or AC97, than your current sound device is setup correctly. This device name above should match what you saw while in control panel's sound and audio devices. If after doing another reinstall & running the setup for mic through windows control panel still fails than the integrated sound chip on the motherboard is defective. If your board is under Asus three year warranty, return for a replacement board. If your warranty has timed out, than buy a PCI sound card & install onto a opened PCI slot.
Good Luck!
Have more questions? Feel free to ask.
Mike
Mar 17, 2008 | Intel Motherboard
Logitech (980158) Headset Logo
414 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
