Xerox C2424 error code 19,003.48 and 07,010.43
Hi guys,
Can someone please guide me on how to open this printer and the position of the printhead. Also how can I lubricate the slider and with which lubricant? I am a complete novice in this field.
  • 1 more comment
  • tyndel Jan 31, 2008
    Thanks, but please where is the printhead situated in the printer? The printer wrote "printhead unpacked" before flashing these codes
    Thanks, but what I am using is xerox c2424 solid ink and not hp or canon
    Thanks for your help but what I actually mean is where the printhead is located inside the printer i.e the position where it is situated and how to access it. This printer does not use catridges. It uses solid ink. If it is catridges I wouldn't be so confused.
  • 226 Answers
For error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
Xerox C2424 error code 19,003.48 and 07,010.43 - c2424-interface-cov-open.jpg
click on this:
for maintainance
for troubleshooting:
Posted on Jan 30, 2008
  • earl llanera
    earl llanera Jan 31, 2008
    did you tried my sulotions for you?
  • 3,422 Answers
here is the user manual for it.
Click here
Im further looking into the error codes.
Dont forget to rate me as fixya..
  • 5 more comments
  • Priya darshan Jan 30, 2008
    FOR lubrication read this:
    This carriage/bar assembly should be assembled perfectly.
    clean and dry; the carriage has brass oilite bearings and any addition of lubricant will dry out and cause jamming because of dust settlement. The bar/bearings do wear eventually leading to a gentle clicking noise whenever the carriage reverses direction but this is not terminal and does not seem to have a major effect on print quality (especially in the Normal or Best modes where printing is unidirectional). Dis-assembly will allow complete cleaning of the bar and the bearings.
    If someone has mistakenly oiled the bar then the oilite bearings will have to be very carefully cleaned as oily dust will get to the inside edges of the bearings as well as the visible outside parts; - difficult to clean up and if not done perfectly the remaining oily dust will reapply itself to the bar and the jamming problem eventually re-occurs. It might be an idea to buff out any scratches/marks on the bar with a buffing wheel - but I have not tried this.
    The carriage also has a rearside oilite slider bearing which should also run clean and dry - use alcahol on swabsticks to clean off all old oil and paperdust residues.
    Try to use minimum dust paper - it will prolong the life of the slider bars and also the rubber rollers of the paper transport system. If your printer lives in a dusty environment - keep it covered when not in use!
    Hi i would also reccomend a $8.83 Synthetic Oil (1/2oz Plastic Bottle - For lubricating the front and rear slider rods
    I would also like u to have a look at this.
    Click here
  • Priya darshan Jan 31, 2008
    click here on the right hand side u will see the diagrams of printhead and where it is located
    Dude the printhead is same for all the catridges there is nothing different in printheads..
    hey go to this link on the right side u will see a video box under that u will see a video for "Easy to load solid ink sticks" select that and the video will start u will understand everything..
    Click here
    So now your problem is solved,
    Don't forget to rate me as fixya..
    You can also check this link it tells u about the error codes and what it means.The second error of urs is XX03 Replace
    Click here to see what "
    XX03 Replace" means
    Goodluck once again and don't forget to rate me as fixya..
I have an error code 07,007.40:10320 any idea what the problem is please?
That is a process motor failure, replace the process motor camshaft kit, part number WCC2424-Z2. The printhead is unable to tilt.
Sep 03, 2015 | Xerox WorkCentre C2424DN All-In-One Laser...
There is a problem eith your printhead.Try to get new printheads
Have you tried lubricating the slider rails, you should do this before replacing anything.
Please don't forget to rate me as fixya..
Jan 28, 2008 | Office Equipment & Supplies
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
Jul 07, 2015 | Xerox Office Equipment & Supplies
Xerox c2424 error codes
Drum disconnect. The drum heater is not drawing the expected
power from the supply.
AC power supplied by power sources such as uninterruptible power supplies (UPS's) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir
heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48).If you do not hav a UPS connected then probably it is the drum heater problem
Aug 05, 2014 | Xerox C2424 Copier
Xerox c2424 fault code 37.002.47:33363
you have problem with your printhead!
Printhead jet-stack heater error
Sep 07, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
C2424: error code 19,993.48:88868
This error is a Printhead error, but in this case is usually more probable to be caused by the Electronics Module.
The Printhead part number is 650-4354-00
The Electronics Module is 119-6427-03
I suspect the actual error code was 19,003.48
Item, Inc.
Oct 03, 2010 | Xerox C2424 Copier
The process motor has stalled while moving the Printhead.
You need to check the wiring to the printhead for proper routing.
Then, remove the printhead and check for ink spills in the tilt and drive gears.
Then, check the gears in the Process gear drive train are correctly aligned, in the coerrect home position, and not damaged.
You might need to replace the Process gearbox.
May 25, 2010 | Xerox C2424 Copier
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
136 people viewed this question
