Question about Samsung MW1030WA Microwave Oven
Micriowave key panel
My GE XL1400 spacemaker (Model No. JVM1450BA001) microwave need a key panel replacement. I need instructions for chaning the key panel.
  • 2 more comments
  • Kripa Feb 03, 2008
    Hi Kripa,
    Thanks for your help. I did change the key panel. The F3 signal has disappeared now. I get the "please press clock" message now. The keys don't work. What could be the problem now. Please let me know. Thanks,
  • Anonymous Feb 04, 2008
    Hi Kripa,
    I still have the same problem. I cleaned the ribbon as you suggested. It still gives me "Please press clock" signal. The keys don't work. Is this a problem with the PC board. Do you think it is better to replace the microwave (from cost point of view)?
  • bernie715 Feb 10, 2009
    key pad doest work right. when you press the 3 on key pad. you get one sec. the start button is the popcorn do you chang the key pad,
  • Anonymous Mar 25, 2014
    We scratched the door panel on our GE microwave model JVM6175. Is there any way to replace the panel?
  • Samsung Master
  • 9,098 Answers
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off. You have to make sure all the old adhesive is off.
Then peel the backing paper from the new keypad and carefully press the new keypad in place. You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 03, 2008
  • William Miller
    William Miller Feb 03, 2008
    Assuming you received the proper replacement part, the keypad connector strip (mylar) may not be plugged into the circuit board connector correctly.
    One half or all of it may not actually be between the metal conductors (pins) in the keypad connector.
    Here is my standard text on keypad disconnection and connection:
    1. Be sure the oven is disconnected from the power line while you are taking it apart.
    2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
    3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
    4. Then the keypad strip will lift out. Clean both sides of the end of the strip with alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
    5. Put the keypad strip back in, making sure both sides are down fully.
    6. While holding the strip down, push the connector back down to lock it.
    7. Try the keys again with the door closed.
    If it still doesn't work, let me know, and feel free to send me a few good digital photos if you can.
    There may be some grease or mineral deposits on the board, and that can interfere with the key operation.
Does the ge spacesaver xl1400 microwave have to mounted or can it just sit on a counter?
Theoretically JVM1400-series microwaves (XL1400 is a meaningless number they put on the ovens) can be used on a counter top, but it's really not safe because it has no feet, and it may slide and fall off the counter.
Also, it will probably not set level on a counter.
You can download GE owner's manuals and installation instructions here.
If you need mounting hardware or other parts, you can get them by by entering your full model number from the tag on the oven here.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
HI - our rotating plate cracked for a JVM1450BA001 micro. Do have a replacement part for this model? I believe it has been discontinued.
Even though the model has been discontinued, the tray is still available. If you go to and enter the model number you should be able to find the tray there. Hope this helps you.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
What is the correct glass turntable part for the GE XL1400 microwave (Mod JVM1450BA001)?
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Or you can enter the original part number
Oct 04, 2009 | GE Microwave Ovens
Spacemaker XL1400
Key panel (touch pad) shorted.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemakerxl1400 suddely stopped heating,all other functions are it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The part number for the Control Panel assmbly is WB07X10789, you can order it from numerous places but has it listed as a special order for 110.00. To replace it first shut for the POWER. there are usually 2 screws in the face of the grill above the door, sometimes in the top of the unit. Remove these then the grill will pull off, just above the control panel there is one screw take that out then lift up on the control and pull out on the top, control panel should come out. Be sure you keep track of the wires attached to the control and where to put them back....
Then you will need to separate the control board from the control panel . After that reverse to reassmble
Feb 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung MW1030WA Microwave Oven Logo
406 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
