Hello, the 2wire single port dsl line filter just stopped working. The Ntwk light doesn't come on (and cannot access DSL) and then the power light went out. I have tried the adapter in other jacks, with the same results. Is this a common problem?
-   I couldn't connect to the internet, when I looked the upper red light was on. So I turned the power off and now no lights will come on. I tried several other outlets in the house, same results. Do I replace the AC adapter or the entire modem?-   Guest
i think when you purchased the 2wire modem it usually comes along with 3 sets of single port dsl line filters, try out those other filters see which one works. if the local network light doesn't come on, (are you using 2wire 1000 series?), check the network adapters in your computer, this usually happens when you are using lower versions of OS. try the power outlet in the kitchen / bathroom, if power light doesn't come on, push the reset button for 30 secs. if power light is still off or red, then you may need to replace the modem (check if it's still under warranty, if not you will need to buy a new one.) also you should be using the same power adapter that came with the modem, check the specs. sometimes if the modem is more or less than 3 years old, they could get defective especially if it's often affected by sudden power surges.
Dlink seems frozen .. the lights for ads power autmatically turn green without attempting any...
(More)
Dlink seems frozen .. the lights for ads power autmatically turn green without attempting any connection .. the ethernight light is red .. even through its got a valid ethernet connection ... problem just started prior to that everything was working well ... Tried to turn off and wait up to 10 mins still no different .. connect the electrical connection .. turn it on and immediately the power and dsl light come on 'green' (normally the dsl light flashes as its connecting and turns green when connected) ... normally the ethernet flashes and then turns green .. now the ethernet light is just red .... Tried to reset .. without luck it won't reset.
Need to open UDP PORT 3658 so I can get EA game to connect on my Wii. How do I do that? Also have...
(More)
Need to open UDP PORT 3658 so I can get EA game to connect on my Wii. How do I do that? Also have several TCPports they recomend opening.
i can get the dsl to operate, or by disconnecting, the phone will work. have tried many filters with...
(More)
i can get the dsl to operate, or by disconnecting, the phone will work. have tried many filters with no luck. I do have a tester, and receive a very weak signal when dsl is wired in. I have the dsl on one seperate wire line to the phone incoming, and a line for the phone. have also tried a different phone. could my red line to the dsl have a short? dsl will work with only green wire attached.
