Question about Microwave Ovens
GE SpaceMaker Microwave JVM1653BD004
My Mircowave runs but doesn't heat. Any ideas on approximately how much this would cost to fix? I rent my place and would have to fix it before moving out but REALLY don't want to buy this guy a new microwave right before I move out.... Anyone out there a microwave guru?
  • Anonymous May 10, 2009
    My microwave will not heat when I turn it on.
  • 43 Answers
WoW!! What kind of a rental lease requires you to repair appliances? Most rental properties have maintainance of appliances included. Read your lease. Are you required to have it repaired?
Could be anything from a Cold Solder Connection on the Cook-Relay Board to a Magnetron.No Simple solution for a Novice. It involves step-by-step trouble shooting with power turned on some steps. Very DANGEROUS!!
Call around, Ask how much for Trip Charge and Estimate of Repair.
Good Luck!
Posted on Jan 29, 2008
  • Totalwreck Jan 30, 2008
    By-The-Way, This was not something you did that made the MW fail. NOT YOUR FAULT!!! This is a built-in failure with GE, Hotpoint, And others built by GE. Look on this Forum at "Have Same Problem".
Mircowave heats propperly, but clock goes blank
Possible fault with your timer controller unit processor board. In many cases insects can cause secretion and so the clock circuit can malfunction. remove the unit and use a air cleaning. heat the board if there is presence of moisture.
Apr 09, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker mircowave not heating- all else works ok
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Feb 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave turns on but does not cook food food does not get hot all other options on oven work fine
you have a bad magnetron . that is the heating source . the part is not cheap. go to sears parts direct and check out the price b4 you have someone check it.
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Oct 10, 2009 | Microwave Ovens
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Mircowave will not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first: (if it's not shorted, it's probably okay)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
188 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
