Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony sxrd bulb doesnt last 9blinks
Have a SXRD model kds60a2000 had replaced power supply solved 5 blink problem now when room temp below 72degrees wont run get 9 blinks and the new bulb only lasted 3 months.is this the lamp driver? and does any one know what lamp voltage is thank you
  • meimff Jan 29, 2008
    used OE bulb is S1 S2 the boards behind fan? 9 blinks suposeingly device code error is this true?
  • meimff Jan 31, 2008
    used OE bulb,lasted 3 months. as to dust issues some dust not an issue. also set works fine if i do not let room temp go below 74 degrees. when it carries on lamp trys to fire and sound and picture start to come up but 3seconds into it she dies and 9 blinks appear.unplug and turn up heat gets it going. cant stress enough every thing works once running. P.S. do you know if fixya has phone in payment abbilities?
  • 21 Answers
IF SET HAS ERROR 9 THEN THE S1 and S2 board ARE PROBABLY THE REASON. DID YOU USE ORIGINAL SONY LAMPS ? GENERIC LAMPS (ESPECIALLY IN SONY) DON'T LAST. AND IS THE SET IN A CABINET ? I HAVE ALSO SEEN PROBLEMS WITH THE FANS GETTING DUSTY AND THE VENTS ON THE SIDE OF THE SET FILLED WITH DUST.
DON..
Posted on Jan 29, 2008
  • DON BLACKSTONE Jan 30, 2008
    IF YOU ARE GOOD AT TECH STUFF I WOULD SAY TRY TO FIX IT YOUR SELF, BUT IF YOU ARE NOT CAREFUL YOU CAN TEAR CONNECTORS AND DO MORE DAMAGE THAN GOOD. IF YOU HAVE A METER I CAN SEND A PDF FOR TROUBLE SHOOTING..
    IM HAVING TROUBLE SENDING A PDF. FILE IT HAS VOLTAGE CHECKS AND LOCATION OF THE BOARDS. THE ERROR 9 IS A TEMP SENSOR ERROR IN THIS SET. IT IS DEFINITELY AN ERROR ON THESE BOARDS. MOST OF THE TIME YOU CAN JUST REPLACE THEM.
    I CAN GET YOU THE PART NUMBER'S IF YOU NEED. THEY SHOULD NOT BE TO EXPENSIVE THEY ARE SMALL BOARDS.
    THE P# FOR S1 IS
    A-1166-582-AS2 #
    A-1166-583-A
    THE BOARDS ARE ABOUT $75 EACH.
    THIS IS THE BEST THING I THINK..
    DON.
    I WOULD APPRECIATE POSITIVE FEEDBACK.
    THANK YOU..
  • DON BLACKSTONE Feb 01, 2008
    THE S1 AND S2 ARE TEMP SENSING BOARDS, THEY ARE PROBABLY THE ISSUE. IT COULD ALSO BE AN ERROR FROM THE MICRO. I HAVE SEEN THIS IN THESE SET BEFORE. THE ONLY WAY TO SEE IS TO REPLACE THE S1 AND S2 BOARD AND SEE IF THEY HELP. I HAVE A P.D.F. FILE THAT TELLS VOLTAGE CHECKS FOR THIS BUT I DON'T HAVE A WAY TO SEND IT TO YOU.
    DON..
How to replace lamp sony sxrd projection tv model no. KDS-55A2020
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jul 07, 2014 | Sony XL-5100 Projector Lamp for Grand WEGA...
My Sony SXRD 50" has 3 blinking red lights by power/standby I just changed the bulb
I do not know that particular model, you can open the back
And see the power suply module,Take it out and replace .
Should solve your problem.
Oct 31, 2012 | Televison & Video
My 60" sxrd 1080p has
hi sir,
you should buy LMP-H200 replacement bulb,
just i have this model, if you need , please contact me.
Jacky
wanmingjun@gmail.com
Mar 11, 2011 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
I have a Sony Wega SXRD. First issue was the
No. Could be a bad ballast this time. That is the box that energizes the gas to produce light. Bulb has no filament.
Sep 10, 2017 | Sony XL-5100 Projector Lamp for Grand WEGA...
My Sony SXRD power led is blinking and the picture
your power supply has failed repair/replace it
Mar 20, 2010 | Sony KDS-70R2000 70" SXRD TV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
Sony, SXRD Projection TVKDS-55A2000 Was working fine, then picture vanished. We have red blinking light on front, indicating lamp. I presume that lamp need to be replaced, but TV has only been operating...
Same thing happened on mine, you need to replace the bulb, on our TV I have 2 kids so the TV was always on but lasted 2 and a half years which impressed the warranty people. From what I have heard the average life is about 2 years. I have the same SXRD TV.
Aug 10, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Sony sxrd 60 in, won't power up--blinking red light 5 times
You need to replace your bulb. Order a replacement online---it's easy to swap and the instructions are in your manual. If you purchase one from a local dealer you will pay over $150 more!!!
Feb 25, 2009 | Sony KDS-R50XBR1 50" HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
217 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
