Question about Sony KDSR50XBR1 50" Projection HDTV
Lamp Replacement on Sony Wega TV
Hi. It is time to replace the lamp for my Sony KDSR50XBR1 50 Inch TV.
I would love to do it myself, but the Sony manual doesn't tell you where the lamp is located on the TV itself. Can you tell me where on the tv the lamp is located?
  • docsharon Mar 13, 2008
    Thanks to all for your assistance. The door to the lamp was located on the side of the TV by the on/off switch. It was quite easy to remove the old lamp and replace it with the Sony XL 5100 lamp. The new lamp came with very clear instructions on how to replace it. The only tricky part was realizing that the lamp slides in at an angle, and that you really needed to push it in with more force than you would think to hear it click into place. The lamp cost $250. I could have purchased similar lamps for less, but I wanted to use the Sony brand which contained the lamp and it's housing. There are cheaper priced lamps available on the web, but read carefully. Some are only the bulb, and not the lamp and housing.
  • 4 Answers
You can save some $$ by replacing only the bulb. Cost of bulb with housing is $250, bulb only is about half that. See how here:
http://www.geocities.com/bob_lipp/Instructions.html
Posted on Mar 13, 2008
Lamp is located on side of TV. Same side as Power Button. Remove one screw, open door, Pull ring up and out and bulb assy comes out. Tricky to re-install though.
Posted on Feb 18, 2008
Is your TV still under warranty? If it is, then you should send it back and let them fix it. If you do it yourself, you might void the warranty.
Posted on Jan 29, 2008
Sony wega/60 inch would not turn on,is it the lamp or some thing else.
The tv LED light "LAMP" indicator flashes or lite up?Tv Projection lamp been inside this tv like about 2 years already,tv on and in used everyday like 4 or 5 hrs daily?Yes,than the tv projection lamp life are ended and require tv projection lamp replacement.
Jun 15, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a Sony Wega 42", my picture went out! Now there is a lamp light flashing? What is this?
Flashing lamp light indicates that tv needs lamp replacement as existing lamp is dead/ broken.
Replace lamp in tv to solve this issue, please buy Sony original lamp for good picture in tv.
Thanks.
Dec 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv stays on for a few minutes and then goes off;after 30 seconds,blue light flashes,and tv goes on again;
If it is Sony Grand WEGA KDF-55XS955 tv then it needs lamp replacement as existing lamp in tv has reached at end of its working hours life and causing this problem.
If lamp in tv has not been replaced in last 2-3 years then it is time to replace it. Lamp replacement procedure is easy and written in user manual.
Required lamp part number for tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL2200U
Available in Sony Accessories Store for $200
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Nov 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Wega television has a red light flashing that says lamp
When Sony tv shows lamp light that means lamp inside tv is dead/ broken and need to be replaced.
Thanks.
May 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega 55 inch, won't turn on and displays shows lamp problem? How do I resolve this? Thanks
Please replace lamp in TV and lamp replacement procedure is written in user manual of TV.
Please buy Sony original lamp for your TV and avoid aftermarket / cheap lamps.
Need further info, let me know with model number of Sony TV.
Apr 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
254 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
