Colorwheel may be bad or the power supply is.
Testimonial: "super fast responce thank u so much for your kind input"
first check to see if it's overheating. there is a thermal shut off if the projector gets too hot. blow out any dust with canned air. if that is ok, it would most likely be the power supply. if the projector gets too warm (or just from excessive use), the capacitors on the power supply (and/or the lamp ballast) will dry out and no longer hold the proper charge. if the caps are puffy, you can replace them. if they are not puffy, it's hard to determine which one is bad. best to replace the board.
I have hp 3222 projector power switch is not working
color wheel spin bulb ignite all fans rotate and then 4-5 sec every thing turn off. after 10 sec while the ac cord stil inside can try again all cycle with the same behavior .is that power suplly issue?
what can be bad inside the power suplly board?
