There is no fuse for this. Its possible the brake switch is bad even if the brakes lights work.
If your transmission lever will not come out of Park, you have a blown Brake fuse, or a bad brake switch above the brake pedal.. The fuse is in the interior fuse box, under the dash, driver side.
We hope that this helps you out.
The ignition switch is turned to the RUN or the START position.
When the ignition switch is in the RUN or the START position, the current flows from the B/U Lamp fuse located in the underhood bussed electrical center (UBEC) through CKT 839 (PNK) to the park/neutral position switch. The park/neutral position switch also feeds the backup lamps portion of the switch. With the transmission in the PARK position, the current flows to the BTSI fuse located in the underhood bussed electrical center (UBEC) through CKT 275 (LT GRN). The current then flows to the TCC/stoplamp switch through CKT 584 (LT GRN/BLK). The current continues to the BTSI solenoid through CKT 1135 (DK GRN/WHT). The ground path is provided through CKT 1850 (BLK) to G207. When the brake pedal is depressed, the normally closed contacts in the TCC/stoplamp switch open and the current flow is interrupted. When the current flow is interrupted, the BTSI solenoid de-energizes. The transmission may then shift to another gear. When the transmission shifts to another gear (except PARK), the contacts in the park/neutral position switch open. This condition stops the current flow to energize the solenoid when the brake pedal releases.
Whic
The automatic transmission shift lock control switch.
The park/neutral position switch.
With the ignition in the ON position, battery positive voltage is supplied to the park/neutral position switch. When the transmission is in the PARK position the contacts in the park/neutral position switch are closed. This allows current to flow through the switch to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid, locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, causing the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Park Lock Solenoid
The park lock solenoid is a safety device that prevents an inadvertent shift out of PARK when the key is in the OFF position. The key must be in the RUN position to release the park lock solenoid. The system consists of the park lock solenoid. With the ignition in the ON position, voltage is supplied to the park lock solenoid. The park lock solenoid energizes through a permanent ground unlocking the shift lever. With the ignition in the OFF or ACCY position the park lock solenoid de-energizes and locks the shift lever in the park position.
Shift Lever Does Not Move with Brake Pedal Depressed
DEFINITION: Transmission shift lever will not move out of the PARK position with the ignition ON and the brake pedal pressed.
Did you perform the Symptoms - Automatic Transmission Shift Lock Control tests and all the necessary inspection?
Go to Step 2
Go to Symptoms - Automatic Transmission Shift Lock Control
The brake to shift relay
The rear integration module (RIM)
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally --closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed ?
