Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Red color gone on tv?
The red is gone and can,t adjust it back? the rest of the picture is fine. the tv is just over 3yrs old with original bulb? what can i do?
    Sergeant:
  • 395 Answers
Is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Posted on Jan 29, 2008
  • Maria Ortiz Jun 20, 2013
    it worked got the colors back ;)
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
Colors dont align
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
Jan 28, 2009 | Televison & Video
Picture problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 24, 2008 | RCA P52771AT 52" Rear Projection...
My picture has a green and blue hue to it.
After spending a day trying to fix the TV, I found out the problem was actually with my cable box. I have an HD DVR recorder. We unplugged the cable box and plugged the TV directly into the cable in the wall and it worked. So we took the cable box back to our cable company and got a new cable box. (Can't live without the DVR!!)
Apr 28, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How do I decrease the amount of green in the picture?
Unfortunately this model has a bad CRT. If is 3-4 years old and the greenish picture is in all inputs, for sure the picture tube is gone. If the picture is green only in component input check the connections for the blue and red cables.
Dec 26, 2007 | JVC AV-27230 27" TV
Picture is mostly red
might try to grayscale but that usually means taking the back off and making the adjustments
Oct 30, 2007 | Quasar SP-3233 TV
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
