Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectric used ribbon won't wind into spool
My boss (in his seventies!) uses an old Selectric typewriter, the model that uses correction tape. The used ribbon suddenly will not wind onto the spool on the right side of the cartridge. He asked me to take a look at it, because he can't figure out why it won't move. I am somewhat mechanically inclined, but could not seem to get anything to move or even to remove the cartridge. The lever on the right side, which I presume allows the cartridge removal, does move easily back and forth. Any suggestions as to what might be causing the problem? Thanks!
  • merrygirl Feb 08, 2008
    Still can't get my ribbon to wind--tried everything. Any other suggestions??
  • 478 Answers
The ribbon sometime gets wrapped around the ribbon driver,One lever on the right side only releases the lift off tape for removal the other is for ribbon removal, also check that the ribbon is on the outside of the ribbon tensioner where the ribbon exits the cartridge on the left side ( a wire thing with a plastic tube on it.
Posted on Jan 29, 2008
Changing correction ribbon
First this is old school after hitting the correction you must press the letter you are trying to correct. if you knew this and the correction tape is properly installed and lifts up you may have old supplies, If you want to talk yuo can call me.
DickyO
216-269-3918
Dec 05, 2014 | IBM Correcting Selectric Iii Typewriter...
IBM Selectric II Ribbon Not Advancing
First check to be sure that the ribbon is on the left of the shock wire where it comes out of the cassette, if that is OK then check the ribbon driver it should move freely and swing to the ribbon take up spool. Some WD40 will free it up. Also be sire the ribbon is winding in the direction of the arrows.
DickyO
Jun 15, 2009 | IBM Office Equipment & Supplies
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Trying to replace the lift-off tape on an IBM Selectric III
Open the gray lever to the right on the carrier.this will release tension on the correcting tape. Now put the supply spool on the left side and bring the take up spool across in front of the card holder. There is a little black wire just right of the card holders opening that looks kind of like a bobby pin , this is the
separator between the ribbon and the correcting tape.The ribbon is in front toward you and the correcting tape is behind. Continue feeding the correcting tape to the take up wheel and take up the slack in the tape then close gray lever.
Mar 24, 2009 | Office Equipment & Supplies
Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Mar 11, 2009 | Office Equipment & Supplies
IBM Selectra III typewriter
There are two different ribbons for selectric III T/W's. One has the ribbon guides as part of the cassette the other the guides are part of the machine.
Be sure the ribbon and L/Oare installed properly and the ribbon is winding on the take up spool properly (counter clock wise) and if the guides are in the machine id to the left if thr white slacker finger just L. of the ribbon also be sure the L/O tape is behind the black seperation finger and the ribbon is in front of it (just to the rt. of the opening in the plastic card holder).
DickyO
Oct 30, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Lexmark Wheelwriter 15 Series II Typewriter Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
