Question about Dishwashers
Midea dishwasher WQP12-924OA wont go alarm sounds when turned on and than the second light flashes
  • 2 more comments
  • Anonymous Feb 26, 2008
    My exact same dishwasher has the same problems alarm sounds and the 2nd light flashes
  • Anonymous Aug 03, 2008
    Hi there, My midea dishwasher is the same style no but stainless steel. It is stuck on a rinse cycle and just beeps or sometimes it will clear and just keep washing not go onto any other cycle??? Have tried to clear it by holding down the reset button but it does not seem to help?? Pretty frustrated with it as it has happened before and fixed itself but not this time.
    Thanks
  • parvin512 Jan 05, 2009
    I have a stainless steel Media dishwasher, bought is last year. It stopped working a few weeks ago. The power light is on but dishwasher doesn't work. Any solution?
    Thanks
  • Anonymous Jan 19, 2009
    Hi i have a midea dishwasher - stainless steel, however the heating element is not working now and i lost the manual. Does anyone have the manual which can refer to? Thank
I had the exact same problem with the exact same model. It sounds unlikely, but I couldn't get it to work until I clipped the drain hose into one of the clips 2/3rds of the way up the back.
There was a sticker there that said "the drain hose must be attached to the left or the right clip"
Posted on Jul 30, 2008
Hi, I have the same dishwasher. Mine just doesn't start at all. The power light is on but the dishwasher doesn't work. We bought it just a year ago. Any solution? Thanks
Posted on Jan 05, 2009
  • Stormin Nov 29, 2011
    Hello, same model for me. Had it fill then hum with no water being pumped. Bought capacitor for pump motor ($4.95aud). Put back together but then diff error, seemed overfill, there is a foam block with micro switch on bottom tray, adjusted switch arm, put back together and now all running ok.
Hold power button down for 10secs while plugging in mains
Posted on May 07, 2008
Check door latch micro switch, common problem with all these chinese dishwashers.
Posted on Jan 28, 2010
Zdt12011fa dishwasher is built in and the flood alarm is in operation - how do I reset?
First you need to remedy failure or any leakage than reset appliance.
Under Reset I mean to delete all alarm stored in memory.
1. Turn off the dishwasher.
2. Press and hold S1 while switching on the dishwasher. Keep
holding the Program button until:
- LED L1 blinks, L2 and L3 is on
- Release S1
3. When L1 is blinking, L2 and L3 is on, press the S1 before L2 and
L3 is turned off.
- LED L2 is blinking, L1 and L3 is turned on.
4. Wait till L1 and L3 is turned off, then press S1
- All used LEDs flash 5 seconds on 1 second off repeatedly.
- If buzzer is equipped, it beeps for 5 seconds
- The alarms saved in the memory are erased
5. Switch off the appliance.
26259192-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Dado
Aug 14, 2016 | Zanussi Dishwashers
Hi i just bought Electrolux Dishwasher ESF2433W When i first time turn it on, the "Normal" button light keep on flashing with beeping sound. According to the trouble shooting manual, it actually refer to...
If you just bought Dishwasher ESF2433W I suggest you contact an authorized service center because the appliance is under warranty..
E4 : if overflow micro-switch is act and keep for longer than 2 seconds, the E4 would occur. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown.
Sometimes defects are generated by incorrect transportation appliances so that should be taken into consideration.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Start light flashing. Unable to adjust
water not entering machine start light flashing and alarm sounds
Nov 13, 2010 | Tecnik TDW2677 Built-in Dishwasher
Flashing lights
sounds like you have a after market alarm that is not connected to a siren. so you get the flashing lights. what you need to do is locate the alarm brain usally under the dash near the steering colunm and unplug it. this will correct your problem.
Mar 24, 2010 | 1997 Subaru Outback
1999 olds aurora when you turn the key just says clean key wait 3 minutes
the key has magnet on it that may be weakening. It will have to be reprogrammed.
  1. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
  2. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
  3. Insert a new Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new key has been programmed.
Jul 07, 2009 | 1999 Oldsmobile Aurora
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Fails to start Midea dishwasher WQP12-9240AS
Thankyou Loopyloolisa! you just helped me fix my unresponsive midea dishwasher! Great help
Jan 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
3,623 people viewed this question
Top Dishwashers Experts
