Question about Kitchen Ranges
Error Code F7 during Self-Cleaning
30 minutes after starting the self-clean cycle on my GE JGBP86WEA gas range, the F7 error code appears. From reading your advice to others with a similar problem, I've decided I may need to replace the ERC. Can you tell me what part number that might be?
  • 5,911 Answers
This indeed indicates a problem with the Electronic Range Control (ERC). The part number for your range is 769758 and costs about $120. You can find the part at repairclinic.com and have it shipped directly to you for a modest shipping fee. If you need further guidance let me know. I hope this information is helpful.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Kenmore self cleaning electric range issue with F10 error during self cleaning mode
You most likely have a failed oven sensor or the control / clock has failed. Self clean mode lets the oven get extremely hot and sometimes causes electronics to fail.
Nov 18, 2017 | Kenmore 30" Slide-In Electric Range...
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Magtay self cleaning oven. I let it clean and now
Did you interrupt the cleaning cycle if so that is why the error code, or a power failure during the cleaning cycle. You may have to unplug the stove for five minutes and then plug it back up, it should reset.
Nov 05, 2009 | Maytag 30" Self-Cleaning Freestanding...
Error code F7 and controls will not work
I think it have  F7 error not just F...
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
May 02, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Alarm sounds as F7 appears when oven is about 90 minutes into self clean
you may need to replace the main control..
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 11, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F7
No F7 in my tech sheet Could it be a F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad if you want to do it yourself let me know...
Aug 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Kitchen Ranges Logo
238 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
