Question about Sony NWZ-S615F Walkman Video MP3 Player
Sony help wont turn off just a screen with the sony sign
  • 2 more comments
  • Anonymous Oct 17, 2008
    went i tried to charge it the screen didn't have anything on it it just looks bleary
  • Sean M
    Sean M Nov 06, 2008
    Mine has been doing basically the same thing. At first I noticed that when I connected it to the computer to charge. it was having trouble detecting the USB connection, giving me messages like "Unrecognizable Hardware" and such. After wiggling the cable a bit it would eventually connect. Well after this started happening I used it for a while until the battery died completely and when turning it on I received a message on the MP3 itself saying "Battery Low, Please Charge" now when I tried to charge it, nothing would happen even after some cable wiggling, and yet this time the computer knew what was connected as I could play the music on Media Player, but not play the MP3 itself. After I disconnected it from the computer the screen of the MP3 remained the same and would not allow me to turn the player off or perform any functions at all (and yes the hold button is in the OFF position). I've also connected it to my LCD TV and the same thing occured; music would play on the TV but the MP3 itslef would not function. Well just today I connected it to the TV and I saw the old charging message appear on the screen, but the backlight would not come on. I let it charge and scrolled through the menu (holding it up to a light in order to see) and hit play. Nothing happened, in fact the screen went black and the backlight came back on dimly, with nothing displayed to illuminate. Now every now and then the music pops in and out, but I'm fairly certain my headphones are broken. The thing is that while I could hear the music, I had no control over the player. With the hold button OFF, I could not control volume, pause/play, FF, RW, or anything; I can't even turn the player off. *sigh* this was a mouthful but I would like this thing to work.
  • witchy_angel Apr 16, 2009
    I REALLY REALLY NEED YOUR HELP. MY SONY NWZ-S615F WALKMAN DOES NOT FUNCTION WHEN IT SAYS "LOW BATTERY". I PUT IT TO THE COMPUTER VIA THE USB CABLE (AS ALWAYS) BUT IT DOES NOT SEEM TO RESPONSE. THERE IS JUST A PURPLE SCREEN OCURRING "WALKMAN SONY....." I CAN ONLY SOLVE IT AFTER I PRESS THE "RESET" BUTTON ON THE BOTTOM OF THE WALKMAN. BUT EVERY TIME I HAVE TO PUSH "RESET" OR THE WALKMAN STALLS. HOW CAN I SOLVE THIS,THIS IS REALLY IMPORTANT!!!
    it will be just good after resetting. but every time you have to reset before charge, unless it does not work!!
Thanks , i had same problem , pressed reset button , now its fine !!
Posted on Apr 07, 2009
    Problem Solver:
  • 6 Answers
Okay I pressed the reset button located on the bottom of the MP3 next to the USB port and now it's working just fine. You could try that, if it hasn't already been suggested.
Posted on Nov 06, 2008
  • 8,596 Answers
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Posted on Sep 14, 2008
Games wont load disc sign isnt coming up on screen
You must send your Playstation to Sony. Sony would be the only people that would know how to fix your problem. Sorry I could not be more helpful.
Oct 24, 2010 | Sony Playstation 3 (PS3) Console
Wont let me sign in.says error 8001000a and says
Have you tried to test your connection. Or maybe you should turn it off from the back, along with any other device you have plugged into it, wait 2-3 minutes, and turn it back on. Hope this helps
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 wont work, just stay's on the wave screan
http://www.fixya.com/support/t1094202-ps3_freezes_startup
go here and see how another fixya expert resolved the problem.
It is something to do with an updated patch.
I hope this helps
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
Mobile phone
HELLO! I HAVE A SONY ERICSSON CELL PHONE.
I DO NOT FOUND DRIVER FOR IRD DEVICE. MY PHONE IS SONY ERIKSSON K 500i. pleas help my.
Jun 18, 2008 | Sony Ericsson W800i Cellular Phone
My playstation 3 wont work
PS3 have been having trouble with most PS3 with 40 gb drive
you have a ONE YEAR WARANTEE, from date of purchase.
I suggest you call sony and request a shipping box to send back your PS3.
If heard alot of people having this trouble.
so CALL SONY!!
Jun 05, 2008 | Sony Playstation 3 (PS3) Console
Wont work
Here is a list of official troubleshooting from Sony for the PS3.
Click HERE
Jun 04, 2008 | Sony Playstation 3 (PS3) Console
Sony ericsson w600i
you can go to topsony.com and sign-up this is a paysite , you need to download the firmware flash for the phone.......or take it to a mobile service center and have them reflash the phone for you, this should fix the problem you are having with it.
Jan 04, 2008 | Sony Ericsson W600i Cellular Phone
Lens wont open
motor drive is shot- tell Sony customer support Be prepared to but a new camers when you see the repair quote.
May 19, 2006 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony NWZ-S615F Walkman Video MP3 Player Logo
253 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
