Question about IBM NetVista PC Desktop
VGA/MOTHERBOARD I have a problem with booting my computer. When booting up everything appears to run H/D fans ect but I have no VGA signal. It supports the MSI PM8M3 VH M/Board. I have done most of the usual checks like taking out the memory and replacing it and unplugging just about everything and reconnecting it but still no VGA signal. It has on board graphics, could this be the problem... thanks I have a problem with booting my computer. When booting up everything appears to run H/D fans ect but I have no VGA signal. It supports the MSI PM8M3 VH M/Board. I have done most of the usual checks like taking out the memory and replacing it and unplugging just about everything and reconnecting it but still no VGA signal. It has on board graphics, could this be the problem... thanks
  • Win_47 Jan 31, 2008
    Yah!!
    Thats Ok now!!!
    Yhanks!!!
  • 145 Answers
Try hooking up to the onboard card and check the video settings in yor bios. Usually press f2 to get there on bootup. Select VGA graphics.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Computer is not booting to windows
Reseat the ram. If that doesn't work, try reseating whatever you can --without shorting out the chips. Follow proper procedure for not frying your setup with static electricity while you do this.
Here is a link offering the possible fix and/or some company in similar situations.
Computer fans turn on but nothing else
Sep 18, 2017 | Computers & Internet
Boot up hp pavilion a1340n and get no vga signal
Have you checked , verified monitor cable, pins bent? You can try a PCI or better a PCI e Graphic Card. Does it boot? Have you tried another monitor?
Dec 25, 2012 | HP Pavilion a1340n PC Desktop
P4M800 Wont boot
Hello there:
please try this first unplug the power to the computer
next open the case and unplug all of the cables and cords that connect to the harddrive cd rom ect ect
now locate the power supply cord that goes to the motherboard and disconnect
press the power button on the computer for 20 seconds and also if you have a reset button press it . what this hoes is releases any stored esd that is in the computer ..
now plug in the power supply back into the board and plug in the power cord and try to boot the computer and see if it comes on if so great just plug in the cords to the cd rom harddrive ect ect and than reboot and you should be ok
Sep 23, 2009 | Biostar P4M800-M7A Motherboard
I have an HPa6700y I purchased about three months ago.  At the time of purchase I installed a high-end graphics card myself (ASUS EAH4870 DK/1G Radeon HD) and it had been running beautifully until...
usually there are 2 problems: 1. a vga card overheat when running 3 games the vga card heats up. try using an case fan or adn a vga fan. 2. the game uses a high refresh rate in this case tri to set a default refresh rate from the vga driver. hope this helps
Jun 14, 2009 | Computers & Internet
Pc monitor blank
Perform a system restore to see if it will restore your settings.
May 12, 2009 | EliteGroup GF8200 MCP78S AM2+ Atx 32GB...
Replaced motherboard, no signal on monitor
IF THE COMMUNICATION PORT FOR YOUR DEVICE IS NOT UNBOARD THAT IS IF THE KEYBOARD, MOUSE AND YOUR VGA CARD ARE THE REPLACEABLE ONE, TRY TO CHANGE THOSE CARDS THEY MIGHT NOT OK ANY MORE. IF YOU STILL HAVE SAME PROBLEM THEN THE MAINBOARD IS NOT OK, ALSO, YOU CAN CHECK YOU MEMMORY CARD THAT IS RAM IF YOU DON'T ATTACH IT PROPERLY IS CAN CAUSE THE PC NOT TO BOOT. IF IS RAM FAULT YOU WILL BE HEARING SOUND FROM YOUR BOARD, ATTACH IT PROPERLY.
Nov 19, 2008 | Compaq (203966-001) Motherboard
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
VGA/MOTHERBOARD
yep. try disable on board card (if there is a setting) and use external video card.
Jan 08, 2008 | E-Machines eMachines Refurbished EMA...
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
Monitor not Running(shows only orange light)
Unplug everything from the motherboard leaving only processor, fan and memory and try to boot up. It will take you to bios screen halt after looking for boot device. If it uses a video card, make sure video card is properly inserted. Then start plugging in hard drive and other devices if system comes up.
Dec 26, 2006 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
IBM NetVista PC Desktop Logo
308 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
