Question about Canon PowerShot A75 Digital Camera
Camera just froze up.
Hi, my sweet Cannon Power Shot A75 just all of a sudden
froze with the lens out...just nothing works. I so miss it.
Jerri Anderson
  • Anonymous Apr 02, 2008
    i have the same problem, it just froze up!
  • Anonymous Apr 17, 2008
    My camera did the same thing. I was using it and it all of a sudden froze with the lens out. I put new batteries in and it is still frozen.
  • 21 Answers
Try Rebooting the camera. Take out the existing batteries and insert some new ones. Then, turn it on and the lens should go back inside!
Hope this helps.
Posted on Jan 29, 2008
SOURCE:
PowerShot G5 Digital Camera: Cannon power shot will not turn on and lens were n...
there is a switch inside the battery cap, when it open, the switch is turning off, then switched on when it closed. the camera wouldnt turnd on, when the swich not working normally
May 18, 2010 | Canon PowerShot G5 Digital Camera
Close up pictures are blurred
Try setting camera into Macro mode. Its the button on the rear which looks like a tulip. Press it again to return to normal shooting.
Mar 28, 2009 | Canon PowerShot A75 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Cannon a75
I am having the same problem and I have found out that there is recall for this issue. You can go to the following website for more info and instructions.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=9828
Sep 29, 2008 | Canon PowerShot A75 Digital Camera
Canon Power Shot S21s screen is black
Hey birdstrike,
According to the manufacturer there are two options. You can try pressing the display (DISP.) button, and if that doesn't work you are probably going to have to get it serviced by an authorized service center. There is a know problem with the CCD sensor on this camera and other model cameras that causes a malfunction when the camera is exposed to heat or humidity. Canon is covering this repair, and I have included a link below to the instructions on what to do.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Sincerely,
Allan
Go Ahead. Use Us.
May 09, 2008 | Canon PowerShot A75 Digital Camera
Cannon power shot a75
Flat cable between screen and r\mainbord damage. If you can open it check for eart wire to lcd if is tighten.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A75 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
