Question about JVC AV-36320 36" TV
Hd dvr Tried to hook it up to a Direct TV HD-DVR. All I got was a vertical split screen and 7" black vertical center...any suggestions? I know it is not an HD TV.
  • noncom23 Jan 29, 2008
    OK, Thx. I'll try it.
    Sergeant:
  • 395 Answers
If you are connecting the dvr via component video cables select the output to 480i and not 480p or other higher formats.the tv cannot support anything higher than 480i. or try using composite video hookup instead.
Posted on Jan 29, 2008
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Dish HD-DVR connected to a Denon 3808ci via an HDMI cable. Problem is periodically, the screen goes black for a split second and then comes back. Rewind and play again the blackout doesn't repeat. When...
Your'e losing digital data from Dish or the DVR. Since even live TV is through the DVR it is always a potential problem when anything glitches. That it doesn't repeat on immediate rewind/playback says the data made it to the hard drive ok.
The Denon is only defaulting back to an analog audio feed upon loss of the digital (preferred) one.
If it affects the video AND audio simultaneously the cause is something common to them.
I'd look at HDMI cabling into the Denon from the DVR.
Don't blame the Denon just yet.
My $.02:
I'd skip the video right past the Denon to the TV/Monitor even if it means using component cables instead of HDMI, but keep digital audio coming in from the DVR. Added cabling and connections never improve anything. Plus, HDMI cables are expensive.
It would be interesting to see if the problem comes back and affects only the audio or the video.
If you use optical cable make sure it has smooth flowing curves and no small-radius bends that would lose light power.
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
Feb 06, 2011 | Denon AVR 3808Ci Receiver
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Sony (KDF42WE655). Always have a video 7 label on the screen
Try these:
  1. Press MENU on the remote control
  2. Select Settings
  3. Highlight Setup
  4. Select Label Video Inputs
  5. Select Video 7
  6. Select None if available or
  7. Leave the label blank
Aug 23, 2009 | Televison & Video
DIRECTV HD DVR REMOTE CODES WILL NOT OPERATE DVR
If you turn off power saver on your tv it should correct the problem...
Mar 02, 2009 | Bose Cinemate Digital Home Theater System...
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Mar 26, 2008 | Televison & Video
Playstation 3 on Sanyo Large Screen HD DT
It would be better if you went diretly threw a video source on the TV. Rn the wires from the PS3 to the tv and then select the source that it is connected to
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Dec 06, 2007 | Televison & Video
JVC AV-36320 36" TV Logo
125 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
