Question about Protron PD-DVR100 DVD Recorder
Protron dvr I am not getting a signal
I am not getting signal
Posted on Mar 31, 2009
The Protron dvr is a piece of junk....mine does the same
Jo Ann
Posted on Mar 09, 2008
6ya staff
SOURCE:
I need to know what hooks on the back of the TV into the mother/sister to provide regular TV. Some sort of converter? Which kind?
The Protron PLTV-32 only has an analog tuner (NTSC). So you need a digital to analog converter to watch OTA programming. A basic d-t-a converter will give you Standard Definition output (480i) (either on the TVs antenna in or the composite in inputs).
Since the TV can show a high definition signal (720p), you could also use an HD tuner set top box. However, these are significantly more expensive than the $40-70 SD converter boxes that were sold for purchase with the government coupon last year. Alternatively you can use a DVR with a tuner as your set top box (computer with a tuner card) to the VGA or DVI inputs on the TV.
I hope this helps.
Aug 16, 2011 | Protron PLTV-32 Television
When recording from vhs tape, and the signal is poor at times, the machine automaticaly stops recording temporarily and resumes when the signal is more stable. how can this feature be disabled?
If you are recording VHS tapes that contain macrovision, and most commercial tapes do, you can't record them with this DVR because it is compliant with the law that says you can't do it. So don't try. Download nearly every movie/tv show from the internet instead.
If you are recording from VHS tapes that you have created yourself from TV sources, or from camera, you must stabilize the picture. There are several devices like that. Do a google search on "vhs stabilizer".
Apr 21, 2009 | Protron PD-DVR100 DVD Recorder
Picture is black and white
If you have it connected to the 'antenna input' on your TV, change the channel up or down, and then back to 3/4 as appropriate. Sometimes the signal from the machine does not match exactly what the TV is looking for, but the TV will figure it out after you change the channel up or down. The AFC (automatic frequency control) will then try to re-tune the channel.
If you have it connected using the composite, and r/w audio, then you likely have a problem inside the DVR.
tom
Feb 16, 2009 | Protron PD-DVR100 DVD Recorder
Emerson Remote Control Code difficulties
You Emerson Jumbo may not be able to control all functions of your Protron DVR but only "off" control seems to be an extreme limitation. I checked my Sentry "workalike" and found no codes for Protron.
May 16, 2017 | Emerson Televison & Video
DVD Recorder will not record.
i have a problem recording from dvr to dvd. i have a coxial from dvr to dvd recorder to tv . but the dvd recorder acts like it has no signal.also on the bottom of the tv screen it comes up copy protected. what the problem
Oct 24, 2008 | Protron PD-DVR100 DVD Recorder
Protron pd-dvr 100 problem
Does Anyone have any idea, where I can buy Board replacement parts for my PD DVR-100
Sep 13, 2008 | Protron PD-DVR100 DVD Recorder
Lost manual
Hey,
Here are a few numbers I found for Protron in a Universal Book I have. No promises, but try these and see if they work. They are for a Protron TV the book says, but it won't hurt to try them, right? Good Luck! Hope they work. Cya, Bill Netter
004
006
012
Feb 28, 2008 | Protron PD-DVR100 DVD Recorder
Protron 37" HDMI not producing sound
Check the volume control on the DVR box. This is sometimes turned down. Good Luck
Mar 29, 2007 | Protron PLTV-37 37 in. LCD Television
Protron PD-DVR100 DVD Recorder Logo
109 people viewed this question
Top Protron Televison & Video Experts
Ekse
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
