Question about Janome D'cor Excel Pro 5124 Mechanical Sewing Machine
Automatic Threader Never works
I have tried and tried and my automatic threader - which was a very major reason why I bought this machine does not thread the needle. I live in the knoxville, TN area and would like to get the machine in for a through over all cleaning as the dealer who sold it to me in Naples, FL went out of business. Please let me know where I should take it where I can get it repaired and learn more in using it properly. Thank you - Cinda Russell
cindarussell@bellsouth.net
Lever the auto threader slightly back and pull down- if it doesnt pull down adjust the needle up or down slightly. Once it is down behind the needle, place thread under far left of threader then pull across to far right and hook behind tiny hook. Sounds complicated but not so when you get the basic action. Release and guide back up and the thread should be thru the hole and looped up bahind it. Hope you get it.
Posted on Jun 15, 2008
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
Usually, the needle needs to be raised so the needle eye will match the threader. However, perhaps your threader has been bent or inadvertently pushed up or out of position.
Jun 06, 2017 | Sewing Machines
The automatic threader isn't working. the bobbin isn't sewing correctly?
make sure the bobbin is turned counter clock wise, also try changing the bobbin, also try a new needle. you may have to have the automatic needle threader checked to see why it's not working
May 20, 2016 | Singer Inspiration 4206
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
Automatic needle threader won't work on brother pe-770
Always make sure the hand wheel is at the exact top. Have you replaced the need recently? If it's bent, then the threader will not work. If the needle is loose or not all the way to the top in the holder, it will also cause the threader to not work.
Jan 06, 2013 | Brother PE770 Computerized Sewing Machine
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
Automatic needle threader stuck in lower position
So sorry I don't have an automatic threader so I'm no help in this department. Good luck!
Oct 26, 2011 | Singer 3116 Simple
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
352 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
